October 22, 2009, 05:38 |
error message when run 'wmake' to compile
Forrest
Rep Power: 16 |
Hi all,
This may be a straightforward thing but I just couldn't figure it out. We installed OF-1.6 but when anything to do with 'wmake' I had an error message saying: :~/OpenFOAM/yingchun-1.6/run/heatTransfer/buoyantPisoFoam/hotRoom/setHotRoom> wmake g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/setHotRoom.o -L/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/serak/yingchun/OpenFOAM/yingchun-1.6/applications/bin/linux64GccDPOpt/setHotRoom /usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/home/serak/yingchun/OpenFOAM/yingchun-1.6/applications/bin/linux64GccDPOpt/setHotRoom] Error 1 This happens when I tried the cases like 'hotRoom (compile 'setHotRoom')', 'cylinder (compile analyticalCylinder)'. Anyone can give some hint what the problem this could be? Thank you Regareds Forrest |
Display Modes | |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 13:28 |
