error message when run 'wmake' to compile
Old   October 22, 2009, 05:38
Default error message when run 'wmake' to compile
Forrest
Forrest_Lei is on a distinguished road
This may be a straightforward thing but I just couldn't figure it out. We installed OF-1.6 but when anything to do with 'wmake' I had an error message saying:
:~/OpenFOAM/yingchun-1.6/run/heatTransfer/buoyantPisoFoam/hotRoom/setHotRoom> wmake
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/setHotRoom.o -L/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/serak/yingchun/OpenFOAM/yingchun-1.6/applications/bin/linux64GccDPOpt/setHotRoom
/usr/local/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: file not recognized: File format not recognized
collect2: ld returned 1 exit status
make: *** [/home/serak/yingchun/OpenFOAM/yingchun-1.6/applications/bin/linux64GccDPOpt/setHotRoom] Error 1
This happens when I tried the cases like 'hotRoom (compile 'setHotRoom')', 'cylinder (compile analyticalCylinder)'. Anyone can give some hint what the problem this could be?
Thank you
Regareds
Forrest
Forrest_Lei is offline   Reply With Quote
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
