what's the difference between "smagorinsky" and "smagorinsky2" ?
Dear Foamers,
I am a beginer of LES, I want to use the standard smagorinsky model. In OpenFOAM, has smagorinsky and smagorinsky2 model. what's the differences between them ? want is the 3-D filter ? In OpenFOAM tutorials directory, only has one case using oneEaEddt, so it can't be used to modify. If use smagorinsky model , them how many variables should be set for initial and boundary condition in 0 directory ? Thank you very much. |
Hey Panda,
Did you ever get an answer to that question? Do you know how to run Smagorinsky2? Somehow it doesn't run with pisoFoam... Regards Stefanie |
I have this question too. Any idea? |
Another question:
As you know Cs can be 0.1~0.2. I think default value is 0.2 for smagorinsky. Isn't it? I want set it 0.1 to decrease diffusion in my simulation. What should be done to do that? Regards, Maysam |
hi everybody,
somewhere I read that Smagorinsky2 is the Smagorinsky model with 3-D filter, is it true? in other word can I use Smagorinsky for 3D flows or I must use Smagorinsky2 instead? can anyone explain the difference between these two models? thanks in advance, Mostafa |
The source code is your friend. Verbatim from their respective header files:
from $FOAM_SRC/turbulenceModels/incompressible/LES/Smagorinsky/Smagorinsky.H Code:
B = 2/3*k*I - 2*nuSgs*dev(D) Code:
B = 2/3*k*I - 2*nuSgs*dev(D) - 2*cD2*delta*(D.dev(D)); |
