-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Setting up: Cube, 2 holes, high pressure inside (http://www.cfd-online.com/Forums/openfoam/69674-setting-up-cube-2-holes-high-pressure-inside.html)
shangzung October 30, 2009 12:27
Hello!
I am trying to set up a very simple cube (6*6*6m), of which two sides are holes. Inside the cube I set a field of 1m with very high pressure via setFields to simulate a detonation. (10,000,000 to 10,000,000,000 Pa)
But it always crashes after about a millisecond.
I try to solve this with the rhopSonicFoam solver. Since this is my first 3D case, I am not sure if I set the right boundary conditions for the walls and the holes. First, in the blockMeshDict I declare the :
patch outlet
(1 2 6 5)
(0 4 7 3)
wall walls
(0 1 5 4)
(5 6 7 4)
(3 7 6 2)
(0 3 2 1)
The boundary conditions in the boundary file are:
outlet
type patch;
nFaces 1800;
startFace 78300;
walls
type wall;
nFaces 3600;
startFace 80100;
Now I am really unasure what kinds of bondary conditions I have to set up in the /0 folder. Here's what I assume:
p)
outlet
type fixedValue;
value uniform 100000;
walls
type zeroGradient;
T)
outlet
type fixedValue;
value uniform 300;
walls
type fixedValue;
value uniform 300;
U)
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
walls
type fixedValue;
Is this setup correct or did I set something wrong?
The error is:
ExecutionTime = 181.34 s ClockTime = 182 s
Time = 0.000486941
Max Courant Number = 0.486019
deltaT = 1.75373e-19
DILUPBiCG: Solving for rho, Initial residual = 4.76267e-15, Final residual = 2.21084e-28, No Iterations 1
DILUPBiCG: Solving for rhoUx, Initial residual = 1.77789e-13, Final residual = 7.59548e-27, No Iterations 1
DILUPBiCG: Solving for rhoUy, Initial residual = 2.84341e-13, Final residual = 1.21384e-26, No Iterations 1
DILUPBiCG: Solving for rhoUz, Initial residual = 1.34266e-13, Final residual = 6.23753e-27, No Iterations 1
DILUPBiCG: Solving for rhoE, Initial residual = 2.98644e-09, Final residual = 1.4146e-22, No Iterations 1
DICPCG: Solving for p, Initial residual = 4.46359e-15, Final residual = 7.24712e-31, No Iterations 1
#0 Foam::error::printStack(Foam::Ostream&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhopSonicFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhopSonicFoam"
#6 main in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhopSonicFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
Greets
