outlet temperature
Old   November 13, 2009, 23:29
Default outlet temperature
sarangarajan
sarajags_89 is on a distinguished road
hi i am trying to do a flow through a cube
i have specified T at inlet
inlet
type fixedValue;
value uniform 280;
now for outlet
{ type ?
what type should i give for "type"?.
it would be great if you can explain me , I am new to cfd.
sarajags_89 is offline   Reply With Quote
Old   November 14, 2009, 05:17
anonymous
muellea is on a distinguished road
The most natural choice would be zeroGradient, since:
  • in most cases you have no idea of the outlet temperature (you want to compute)
  • and the assumption that T won't change much close to the wall is often sufficient. (Same with velocity)
Try to compute it with these BCs and proof if your assumption was fine. If not, may be fixedGradient would be an alternative.
muellea is offline   Reply With Quote
Old   November 14, 2009, 14:48
Default hi
sarangarajan
but doesnt zero gradient for outlet (say for Temperature) mean that temperature normal to outlet doesnt change??.(correct me if am wrong)
Old   November 15, 2009, 03:42
Primoz Ternik
ternik is on a distinguished road
You are right - by using zero normal gradient (a.k.a. Neumann) boundary conditions one assumes "no change" (in normal direction) of particular flow variable. This is quite O.K. type of b.c., but one should assure and model long enough (in the flow direction) section, where such a flow conditions actually occur!
Hope this helps,
Primoz.
ternik is offline   Reply With Quote
Old   November 15, 2009, 04:13
Default hotroom tutorial
sarangarajan
hi
i modified the hot room tutorial
1. i deleted mut,alpha,K to make it simple
2. i changed one face as the inlet and the other as outlet
3. b.c's
for inlet
velocity is specified ,pressure is zero gradient
for outlet
pressure is specified,velocity is zero gradient
4.inlet termperature fixedValue 280
outlet temperature zero gradient
now in the controldict file start time is zero and end time is 1000
when i type ./Allrun only '0' is written. which step did I go wrong
Old   November 15, 2009, 04:48
Default found the mistake
sarangarajan
i should have not deleted the files
can anyone tell me why is k,mut,alpha zeroGradient at inlet?.
Old   November 15, 2009, 10:34
Paul Schiefer
pauls is on a distinguished road
There are two reasons for this:
  1. Because you should understand the basics of CFD before you use OpenFOAM.
  2. Because these are given as boundary conditions.
pauls is offline   Reply With Quote
relative humidity and temperature by outlet Bing FLUENT 5 March 7, 2014 06:03
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
inlet temperature = outlet temperature Thierry FLUENT 4 March 17, 2006 10:14
Setting of the outlet temperature Chinna FLUENT 0 November 29, 2003 12:42
Question on checking incell temperature at outlet Guoqing Phoenics 1 June 4, 2003 17:50
