laplacianfoam with solidification
I'm trying to add solidification to laplacianfoam (I'm not interested in convective flux, but only in conduction with heat source). My problem is that the temperature I have calculated in a simple test doesn't seem correct (a simple square cavity with uniform temperature inside, 700°C, and fixed temperature to the rigth wall, 500°C). The temperature decreases too fast! Modification to laplacianfoam: Info<< "\nCalculating temperature distribution\n" << endl; for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readSIMPLEControls.H" for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( rho * cp * fvm::ddt(T) + Lh * rho * fvc::ddt(alpha1) - fvm::laplacian(kT, T) ); alpha1 = max(min((T-Ts)/(Tl-Ts),scalar(1)),scalar(0)); Info<< "Liquid phase volume fraction = " << alpha1.weightedAverage(mesh.V()).value() << " Min(alpha1) = " << min(alpha1).value() << " Min(alpha2) = " << min(alpha2).value() << endl; alpha2 = scalar(1) - alpha1; rho = alpha1*rho1 + alpha2*rho2; cp = alpha1*cp1 + alpha2*cp2; kT = alpha1*kT1 + alpha2*kT2; } runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return(0); Modification to Createfield: Info<< "Reading transportProperties\n" << endl; IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); dimensionedScalar rho1 ( transportProperties.lookup("rho1") ); dimensionedScalar rho2 ( transportProperties.lookup("rho2") ); dimensionedScalar cp1 ( transportProperties.lookup("cp1") ); dimensionedScalar cp2 ( transportProperties.lookup("cp2") ); dimensionedScalar kT1 ( transportProperties.lookup("kT1") ); dimensionedScalar kT2 ( transportProperties.lookup("kT2") ); dimensionedScalar Tl ( transportProperties.lookup("Tl") ); dimensionedScalar Ts ( transportProperties.lookup("Ts") ); dimensionedScalar Lh ( transportProperties.lookup("Lh") ); Info<< "Reading field T\n" << endl; volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field alpha1\n" << endl; volScalarField alpha1 ( IOobject ( "alpha1", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh ); Info<< "Calculating field alpha2\n" << endl; volScalarField alpha2("alpha2", scalar(1) - alpha1); Info<< "Reading field rho\n" << endl; volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field cp\n" << endl; volScalarField cp ( IOobject ( "cp", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field kT\n" << endl; volScalarField kT ( IOobject ( "kT", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), mesh ); Can someone tell me where am I wrong? Dario |
the problem is in the source term that is always 0. How can I use the old value of alpha1, to compute: Q = Lh*rho*(alpha1-alpha1OLD)? Dario |
