-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   particle tracing (http://www.cfd-online.com/Forums/openfoam/70053-particle-tracing.html)
CYMa November 13, 2009 04:22
particle tracing
i am new in applying OpenFOAM.
May somebody tell me which FOAM i should use to simulate particle tracing in a gas flow (no chemical reaction between particles and gas).
Thank you very much!!!
andrewryan November 13, 2009 15:24
Hi
Reading Nikas Nordin's thesis is a good start [1]. Then you should try out icoLagrangianFoam [2] If you want to learn the details about how lpt works in OpenFOAM read. [3] There are already some interesting posts on this forum, search for lagrangian or particle tracking.
Nils
[1] http://powerlab.fsb.hr/ped/kturbo/Op...sNordinPhD.pdf
[2] http://openfoamwiki.net/index.php/Co...LagrangianFoam
[3] http://www.cfd-online.com/Forums/ope...mentation.html
gschaider November 18, 2009 14:12
Originally Posted by andrewryan (Post 236188)
Hi
Nils
I would discourage the usage of icoLagrangianFoam. It is sooo pre-1.5 (in 1.5 the particle system changed a lot and there are lagrangian-solvers that come with the distribution (some of them in the tutorials). ILF compiles on 1.5, but is not state of the art)
Bernhard
andrewryan November 19, 2009 03:47
What pieces of code would you recommend instead? dieselFoam?
gschaider November 19, 2009 05:29
The last time I looked at it, it was "old school". Have a look at the solvers in $FOAM_SOLVERS/lagrangian (and there are additional solvers in $FOAM_TUTORIALS/lagrangian). If you're lucky you'll find an intermediate-class that fits your need and which you just have to plug into your solver
Bernhard
