postProcessing with R, I have run,but no file created ?
Dear all.
In version1.6 , I saw a R utility, whick can be used to creat Reynolds stress. But after I have run this ,no file was created . Who khows what is the problem. Thank you! |
Hi - what kind of turbulence model are you using?
The post-processing tool R creates the Reynolds-Stress-Tensor on the base of k - the turbulent kin. engergy. So make sure to run a model which calculates k. Hope this helps you! Good luck. Sven |
