[snappyHexMesh] SnappyHexMesh errors..How to overcome these..
Old   November 19, 2009, 10:14
Default SnappyHexMesh errors..How to overcome these..
vishwanath somashekar
vishwa is on a distinguished road
I had posted a couple days ago regarding the meshing of internal flow geometry say a pipe. When i run snappy, i can see that there is a large number of faces which are non-orthogonal and when run the checkMesh utility after it finishes, i get this at the end of the file
Checking geometry...
Overall domain bounding box (-0.003700000001 -0.007346000057 -0.0004600000102) (0.003700000001 0.001901651965 0.0004600000102)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.21132342e-16 3.586989832e-14 1.385780927e-15) OK.
Max cell openness = 3.10768422e-16 OK.
Max aspect ratio = 20 OK.
***Zero or negative face area detected. Minimum area: 0
<<Writing 7 zero area faces to set zeroAreaFaces
Min volume = 1.931675752e-16. Max volume = 8e-14. Total volume = 1.673317339e-08. Cell volumes OK.
Mesh non-orthogonality Max: 148.2423307 average: 11.06677473
*Number of severely non-orthogonal faces: 78935.
***Number of non-orthogonality errors: 18.
<<Writing 78953 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 7 faces are incorrectly oriented.
<<Writing 7 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 9.963874182, 980 highly skew faces detected which may impair the quality of the results
<<Writing 980 skew faces to set skewFaces
Failed 4 mesh checks.
End
the geometry is very simple.. It has a rectangular box and the end of the box is a half cylinder that is of the same height of the box and the radius of the cylinder is half the box width.
Any suggestions to overcome these errors?.
Regards,
vishwa
vishwa is offline   Reply With Quote
Old   November 21, 2009, 05:59
Cem Albukrek
albcem is on a distinguished road
You need to supply more information such as
  1. the snapphhexmesh dictionary file,
  2. the specifications of the underlying blockmesh (overall size, element sizes)
  3. Copy of the STL file for us to check whether there is anything wrong with it
albcem is offline   Reply With Quote
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
