-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   How to setup problem in OpenFOAM (http://www.cfd-online.com/Forums/openfoam/70459-how-setup-problem-openfoam.html)
devesh.baghel November 25, 2009 05:01
Hi All,
I want to set-up my problem in OpenFoam. I have gone through the user guide, but dint get idea about: How to generate mesh, how to define BC & fluid property & solvers ?
Please some one can help me to find any doc/ link where all the procedure are defined step by step. I have to setup "flow over flat plate" kinda problem.
It was urgently required............
thanks alot :(
mks November 25, 2009 08:32
Use tutorial cases
I would look for an similar case in tutorials-folder (maybe airfoil?), create your own mesh (blockMesh or using Salome), adjust the boundaries in 0/ folder of the case so that them match to your mesh and run the solver. Also look whether the fluid properties are setup in a right way (viscosity? air? water?)
mahendra December 11, 2009 02:27
Hi Devesh..............
you can refer to tutorial cases and documentation in OpenFOAM-1.5 directory in doc and tutorials.
Please go through the documentation first....
Mahendra
