Home > Forums > OpenFOAM
Openfoam on Bluegene
Old   November 25, 2009, 14:41
Default Openfoam on Bluegene
matteo lombardi
matteoL is on a distinguished road
I Have managed to compile succesfully OpenFoam on a Bluegene/P cluster with mpicc (which is a wrapper for gcc+mpi) and it works pretty well, at leats on the first case I used (rasinterFoam on 3.5 mln cells mesh).
I have 2 problems tough:
1)I then wanted to try it on a new mesh, same topology, just a bit more refined and with more cells, 5.5 mln cells.
For some reason, the code crashes. It crashes both when I try to convert the mesh (i use fluentMeshToFoam) and also when i run the rasinterdymFoam. (The same mesh gets decomposed and runs smootly on other standard pc/clusters.)
When I run fluentMeshToFoam it says that:
Building Patch'less mesh.... new cannot satisfy memory request.
This doesn't necessarily mean you run out of memory.. bla bla bla..
I am defineetely not run out of memory, since it was using just 4%of total memory.
When I run rasInterFoam (serial or parallel) it stops while trying to create the mesh. it says:
Create Mesh for Time=0
floating exception
Any idea about what could be the problem? why on another pc runs and bluegene not while on a very simialr ot works on both smoothly?
2)Has anyone managed to compile OF on bluegene/p but with the native compiler (i.e mpixlc)? when i try to do it I get plenty of errors. (Many double declarations of basic function/classes, i.e. dummy_scalar_functions.. and problems with Pstream class)
Any help would be much appreciated since it seems that a code compiled with mpixlc is about twice as fast as a code compiled with mpicc
Thanks,
Matteo
matteoL is offline   Reply With Quote
Old   March 18, 2010, 07:59
andres
andresbh is on a distinguished road
Hi Matteo,
After trying several times to install OF on a bluegene P. I started looking here on the forum and saw your posting.
I am trying to compile OpenFoam 1.6 on a blue gene P but havent been able. I was wondering if you could give me a hint on how to do this.
Have you got a couple of advises you could give me? could you upload the bash and scripts you c hanged to install it.
Thank you very very much
Andres
andresbh is offline   Reply With Quote
Old   March 18, 2010, 08:52
matteo lombardi
hello andres,
thanks to the support of a person at IBM working on openFoam on Bluegene, I managed to install it correctly (i.e. two version, one 32 bit for the nodes, one 64 bit for the cluster..).
Send me a private message with your mail and i will send the settings (it is a tar file of 150kb which apparently is too big to be uploaded...).
Ciao,
matteo
Old   May 12, 2011, 18:29
Yong Wang
ywang is on a distinguished road
I will also work with OF in a Blue Gene/p,,,,But I am waiting the password, and do not know if there will be some unexpected problems,,
ywang is offline   Reply With Quote
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
