-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   nutWallFunction questions (http://www.cfd-online.com/Forums/openfoam/70550-nutwallfunction-questions.html)
madad2005 November 27, 2009 08:15
I'm investigating the wall function approaches used in OpenFOAM. Epsilon and omega wall functions were fairly straight-forward in the end. However, I am looking at nutWallFunction and I'm at a loss as to why nut at the wall is defined as so:
nutw[faceI] = nuw[faceI]*(yPlus*kappa_/log(E_*yPlus) - 1.0); //for y+>11
Why not use the values the computed values of k, epsilon, or omega?
olesen November 29, 2009 04:51
I'm confused - do you mean not using any wall functions at all?
madad2005 November 29, 2009 15:03
Sorry to have confused you; I'll elaborate more. In the k-epsilon and k-omega models, the very last thing they do is compute nut:
//from RealizableKE
// Re-calculate viscosity
nut_ = rCmu(gradU, S2, magS)*sqr(k_)/epsilon_; // (1) nut = Cmu*k/omega
nut_.correctBoundaryConditions();
nut is computed as I'd expected here. Why not use the same equation in nutWallFunction to compute the value at the boundary, as you have k, omega, and epsilon already computed at the boundary face? Is it because you require a general expression for application to all turbulence models?
The reason I've asked is because I'm not particularly conversant in wall functions and I wasn't expecting a different equation for nutWallFunction.
chb November 30, 2009 05:09
  • At the walls
    is used to apply the wall shear stress
    tau_wall = rho * (nu + nut) * du/dy
    according to the log law.
  • For the rest of the flow field
    nut_ = Cmu*sqr(k_)/epsilon_;
    is used to model turbulence effects.
madad2005 November 30, 2009 06:36
Thanks, Christof.
"At the walls
according to the log law. "
Ok, if that's the case, then this is a different form from what I've read other people doing in the past. Thank you, anyway, for helping clear that up.
83_Ale_83 July 28, 2010 09:11
Hi to everybody,
i was looking for the "origin" of this nut equation, It's from:
nut=nu*[(Y+/U+)-1] and U+=1/k*ln(E*Y+) ???
I don't know the origin of the first equation, I have read Pope-Turbulent Flows but in that book nut=k*y*u_t
Thank in advance
Alessandro
83_Ale_83 August 11, 2010 03:49
Originally Posted by 83_Ale_83 (Post 269162)
Hi to everybody,
Thank in advance
Alessandro
Anyone ?
thanks
83_Ale_83 October 13, 2010 05:08
Originally Posted by 83_Ale_83 (Post 271092)
Anyone ?
thanks
Up again please
Anne Lincke October 28, 2011 05:30
Hey Alessandro,
in this thread you might find help:
http://www.cfd-online.com/Forums/ope...-function.html
Anne Lincke October 28, 2011 06:36
Originally Posted by madad2005 (Post 238157)
Thanks, Christof.
"At the walls
Dear madad,
can you please explain how the nut computed by the nutWallFunction applies the wall hear stress according to the log law?
Am I right that there is no explicit near wall treatment for the velocity and the wall function is only enabled via omega, k and nut?
Thank you for an answer in advance.
Anne
