-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   g++ installation in ubuntu (http://www.cfd-online.com/Forums/openfoam/70588-g-installation-ubuntu.html)
aliakbar82 November 29, 2009 03:11
I want to install qt in ubuntu 9.04.I unzipped "qt-x11-opensource-src-4.3.5.tar.gz" file and did every thing in its instruction untill I reached the command make intall;i typed it but saw this error:
make[1]: g++: Command not found
make[1]: *** [.obj/release-shared/qapplication.o] Error 127
make[1]: Leaving directory `/home/moltani/tmp/qt-x11-opensource-src-4.3.5/src/gui'
make: *** [sub-gui-install_subtargets-ordered] Error 2
I think i shoud install g++. if yes how? and if no what I shoud do to solve this problem?
wyldckat December 1, 2009 11:09
Are you using MadsR's install cookbook for Ubuntu? If not, you could give it a shot... although it uses (K)Ubuntu's version of Qt (4.5.1 I think).
As for g++, here is the code line of the script that installs both g++ as well as other packages useful for building OpenFOAM and Paraview:
sudo apt-get install flex git git-core build-essential python-dev libqt4-dev libreadline5-dev wget zlib1g-dev cmake
Best regards,
Bruno
