incompressible, The exact meaning of P in case/0/p ? |
December 1, 2009, 22:27 |
Jiang
Rep Power: 16 |
Dear all:
For simpleFoam solver, what is the exzct meaning of P in case/0/P file ? It is refference value or the actual value ? for initial field and outlet condition , we should set 0 or 101325/rho ? Because I saw many imcompressible case set it to 0, but I set 101325/rho . Thank you very much. |
December 1, 2009, 23:44 |
Masashi Ohbuchi
Rep Power: 16 |
There is no meaning for the value of p in incompressible flow. Only the gradient term of p is appeared in Navier-Stokes eq.
You can start both from p=0 or p=101324/rho, then simulated result may be translate by constant value. |
December 2, 2009, 00:09 |
#3 | |
Jiang
Rep Power: 16 |
I am l little understand, I saw the solver of simpleFoam ,in creatfields,H # include "createPhi.H" label pRefCell = 0; scalar pRefValue = 0.0; setRefCell(p, mesh.solutionDict().subDict("SIMPLE"), pRefCell, pRefValue); The solver will select the pressure reference possition and reference value itself, so I just set the actual value in P file, is it right ? |
December 2, 2009, 04:41 |
Masashi Ohbuchi
Rep Power: 16 |
Yes, specified value for p in 0 directory means difference from reference value. So if you set the reference value of p=0, values in 0/p means absolute value.
Incompressible Ideal gas law | Leverkin | FLUENT | 5 | March 5, 2009 16:41 |
Abt: the speed of sound in incompressible flows | jinwon park | Main CFD Forum | 3 | August 21, 2008 20:44 |
LinearInterpolaterhoU amp meshSf exact meaning | arkangel | OpenFOAM Running, Solving & CFD | 2 | August 21, 2007 05:29 |
Reynold's number and incompressible flow | Neil | Main CFD Forum | 3 | October 24, 2006 08:11 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 16:51 |
