swahono |
December 14, 2010 00:29 |
Originally Posted by alberto
(Post 287308)
Wow.. that's very kind of you! I was going to use my home machine to get the code using SVN.
(Post 287308)
Where do I send the bill? :D
What is your hourly rate?
You can send it to the Australian Govt (my employer) :D
What I can do to repay you is to pass everything I've learned about OF on to other people who are in the same position as me - struggling with OpenFOAM.
Ok, I have re-made your groovyBC
wclean
wmake libso
It returned errors (see error msg below), but I think it still compiled the library.
- I may have gotten the same error message before, but ignored it because the library and BC type is still recognized by OpenFOAM despite the compilation error msg. -
I checked both the GCC version and bison version installed on my machine is as required by groovyBC
gcc (Ubuntu 4.4.3-4ubuntu5) 4.4.3
bison (GNU Bison) 2.4.1
The simulation still crashed on the second iteration using your copy of the newly compiled groovyBC. :(
Just wondering if you had the same error msg ( -See below) as me when you compiled the groovyBC on your machine?
Thanks, Alberto! :)
Kind Regards,
Stefano
The compilation error msg:
$ wmake libso
Making dependency list for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file groovyBCPointPatchFields.C
could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o
SOURCE=PatchValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionLexer.C -o Make/linuxGccDPOpt/PatchValueExpressionLexer.o
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o
SOURCE=PatchValueExpressionDriver.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchValueExpressionDriver.o
rm: cannot remove `Make/linuxGccDPOpt/PatchValueExpressionLexer.C': No such file or directory
In file included from PatchValueExpressionDriver.H:59,
from PatchValueExpressionDriver.C:34:
PatchValueExpressionParser.tab.hh:44:20: error: stack.hh: No such file or directory
lex.ve.c:372: warning: use of old-style cast
lex.ve.c:442: warning: use of old-style cast
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:95: warning: deleting ‘void*’ is undefined
In file included from location.hh:44,
from PatchValueExpressionParser.tab.hh:65,
position.hh: In function ‘bool pve::operator==(const pve::position&, const pve::position&)’:
position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’
PatchValueExpressionParser.tab.hh: At global scope:
PatchValueExpressionParser.tab.hh:309: error: ISO C++ forbids declaration of ‘stack’ with no type
PatchValueExpressionParser.tab.hh:309: error: expected ‘;’ before ‘<’ token
PatchValueExpressionParser.tab.hh:311: error: ISO C++ forbids declaration of ‘stack’ with no type
PatchValueExpressionParser.tab.hh:311: error: expected ‘;’ before ‘<’ token
PatchValueExpressionParser.tab.hh:313: error: ISO C++ forbids declaration of ‘stack’ with no type
PatchValueExpressionParser.tab.hh:313: error: expected ‘;’ before ‘<’ token
PatchValueExpressionParser.tab.hh:316: error: ‘state_stack_type’ does not name a type
PatchValueExpressionParser.tab.hh:318: error: ‘semantic_stack_type’ does not name a type
PatchValueExpressionParser.tab.hh:320: error: ‘location_stack_type’ does not name a type
In file included from Make/linuxGccDPOpt/location.hh:44,
from PatchValueExpressionParser.tab.cc:61:
from lnInclude/PatchValueExpressionDriver.H:59,
from PatchValueExpressionLexer.ll:3:
lex.ve.c: In function ‘int pvelex(pve::PatchValueExpressionParser::semantic_type*, pve::location*, Foam::PatchValueExpressionDriver&)’:
lex.ve.c:9465: warning: use of old-style cast
lex.ve.c:9482: warning: use of old-style cast
lex.ve.c:9495: warning: use of old-style cast
lex.ve.c:9962: warning: use of old-style cast
lex.ve.c: In function ‘int yy_get_next_buffer()’:
lex.ve.c:10141: warning: use of old-style cast
lex.ve.c:10164: warning: use of old-style cast
lex.ve.c:10177: warning: use of old-style cast
lex.ve.c:10198: warning: use of old-style cast
lex.ve.c:10223: warning: use of old-style cast
lex.ve.c:10226: warning: use of old-style cast
lex.ve.c: In function ‘yy_state_type yy_get_previous_state()’:
lex.ve.c:10261: warning: use of old-style cast
lex.ve.c: In function ‘int yyinput()’:
lex.ve.c:10379: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_create_buffer(FILE*, int)’:
lex.ve.c:10478: warning: use of old-style cast
lex.ve.c:10487: warning: use of old-style cast
lex.ve.c: In function ‘void ve_delete_buffer(yy_buffer_state*)’:
lex.ve.c:10513: warning: use of old-style cast
lex.ve.c:10516: warning: use of old-style cast
lex.ve.c:10518: warning: use of old-style cast
lex.ve.c: In function ‘void veensure_buffer_stack()’:
lex.ve.c:10685: warning: use of old-style cast
lex.ve.c:10705: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_scan_buffer(char*, yy_size_t)’:
lex.ve.c:10733: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_scan_bytes(const char*, int)’:
lex.ve.c:10786: warning: use of old-style cast
lex.ve.c: In function ‘void yy_push_state(int)’:
lex.ve.c:10822: warning: use of old-style cast
lex.ve.c:10825: warning: use of old-style cast
lex.ve.c: In function ‘int yy_init_globals()’:
lex.ve.c:10992: warning: use of old-style cast
lex.ve.c:11005: warning: use of old-style cast
lex.ve.c:11006: warning: use of old-style cast
lex.ve.c: In function ‘void* vealloc(yy_size_t)’:
lex.ve.c:11072: warning: use of old-style cast
lex.ve.c: In function ‘void* verealloc(void*, yy_size_t)’:
lex.ve.c:11084: warning: use of old-style cast
lex.ve.c: In function ‘void vefree(void*)’:
lex.ve.c:11089: warning: use of old-style cast
SOURCE=groovyBCFvPatchFields.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/stefano/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/groovyBCFvPatchFields.o
make: *** [Make/linuxGccDPOpt/PatchValueExpressionDriver.o] Error 1
make: *** Waiting for unfinished jobs....
PatchValueExpressionParser.tab.cc: In member function ‘unsigned char pve::PatchValueExpressionParser::yytranslate_(int)’:
PatchValueExpressionParser.tab.cc:4941: warning: use of old-style cast
from groovyBCFvPatchField.H:48,
from groovyBCFvPatchFields.H:37,
from groovyBCFvPatchFields.C:36:
lex.ve.c: At global scope:
lex.ve.c:10809: warning: ‘void yy_push_state(int)’ defined but not used
lex.ve.c:10837: warning: ‘void yy_pop_state()’ defined but not used
lex.ve.c:10849: warning: ‘int yy_top_state()’ defined but not used
