[Sponsors] | |||||
#21 |
Ivo
Rep Power: 3 ![]() |
Thanks for the program and the repository! It works great. Btw ParaFoam segfaults when setting an odd number of cells in the double-grading direction, I didn't notice until a colleague reminded me to check that, then it worked
#22 |
Johannes P
works like a charm, thanks to all contributors!
#23 |
Albrecht vBoetticher
Rep Power: 4 ![]() |
I got the same Floating point exception like Omkar if calling blockMesh after updating the files using hg clone, and blockMeshDoubleGrading is an unknown command, so maybe for clarifying: calling ./Allwmake in the src/mesh folder or at top level? Works with OF 2.1.x?
However I think ist a great tool, especially if one has to deal with internal boundaries like baffles it is cool to avoid half of the blocks. |
#24 |
Anton Kidess
Rep Power: 12 ![]() |
Albrecht, the executable name is blockMeshDG. I will make that more clear on the repository site.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. *Check out the scientific computing exchange http://scicomp.stackexchange.com |
#25 |
Rep Power: 5 ![]() |
Hi Foamers,
Thanks for DG version! One problem found when the O-grid type block mesh was generated. BlockMeshDG switch the grading opposite if midpoints on the block edges are used. This problem does not occur if blocks coordinate system is in same direction, but on the O-grid blocks coordinate systems is not possible keep on same direction. Any ideas fix this problem? Attached case can be run by blockMeshDG on 1.6-ext. BR/Pekka |
#26 | |
sasan
Rep Power: 2 ![]() |
please help me... Thanks, Sasan. |
#27 |
Bruno Santos
Rep Power: 45 ![]() ![]() |
Hi Sasan,
Attached is the modified version for 1.6-ext, based on the instructions from post #3: blockMesh with double grading. Instructions:
Best regards, Bruno
#28 |
sasan
Hi Bruno,
works like a charm. Thank you very much. Sasan |
#29 |
I found the solution to my problem. It's simpler than anybody can guess.
![]() When arc is used on the block edges it is a matter of the order of arc end points. So the grading direction can be changed by switching the end points order: HTML Code:
arc 6 7 ( 1.375 1 1.2 ) => arc 7 6 ( 1.375 1 1.2 ) |
#30 |
steve
Disappointed to see that blockMeshDG still does not seem to be part of the standard distribution. Are the developers not aware of it? How do we make them aware of it? As an OF newbie it was the first thing I looked for when I was creating my first mesh!
About to download and try it for the first time (OF V2.1.1)..... Later: Worked perfectly, but as pointed out by others earlier, you must make sure you specify an even number of cells. I found that if its an odd number, although blockMesh works fine, checkMesh crashes, as does paraFoam. Last edited by greenleader; April 5, 2013 at 23:08. Reason: update after trying it out:) |
#31 | |
Bruno Santos
Greetings Steve,
.Best regards, Bruno
#32 |
steve
Thanks for that Bruno, appreciate you taking the time to reply!
Regards Steve |
#33 |
Hi Foamers,
I tried to install blockMeshDoubleGrading but after wmake I get this error : /opt/openfoam220/wmake/wmake: line 222: make: command not found /opt/openfoam220/wmake/wmake: line 223: make: command not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /tmp/blockMeshDG-1.6-ext and I don't know why. I already succeeded to install this program with another computer.. thanks Anselme |
#34 |
Anton Kidess
Anselme, your error is not related to blockMeshDG, but to your OpenFOAM installation. I'm guessing you can't compile any other program either.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. *Check out the scientific computing exchange http://scicomp.stackexchange.com Last edited by akidess; May 8, 2013 at 02:40. Reason: Grammar |
#35 |
Bruno Santos
Greetings Anselme,
As Anton indicated, you're missing the tools needed for compiling. Check the instructions shown in the section "System Requirements" for the "Source Pack" instructions: http://www.openfoam.org/download/source.php#x6-29000 - that section is all you need to follow, since you've already installed OpenFOAM. Best regards, Bruno
#36 |
Thanks a lot for your answer wyldckat and akidess, it works ! Now I would like to set a parabolic velocity inlet profile but I can't get the sources on
svn checkout http://openfoam-extend.svn.sourceforge.net/svnroot/\ fields/fvPatchFields/derived/parabolicVelocity/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev/src/finiteVolume/\ because of that http://openfoamwiki.net/index.php/Main_Page Someone has an idee ? Best regards, Anselme |
#37 |
Anton Kidess
Anselme, you can use Swak4Foam/GroovyBC. If you run into problems in doing so please start a new thread so we can keep this one focused on blockMeshDG.
- Anton
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| New densitybased solver AeroFoam | giulio_romanelli | OpenFOAM Running, Solving & CFD | 38 | December 5, 2011 11:20 |
| Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
| Parallel rasInterFoam | openfoam_user | OpenFOAM Running, Solving & CFD | 4 | November 1, 2008 05:14 |
| what's wrong about my code for 2d burgers equation | morxio | Main CFD Forum | 3 | April 27, 2007 10:38 |
| REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
