Free surface boundary types
I am quite new to openfoam and cfd however I have been trying to simulate two phase flow around a block using interfoam (air and water, block half in half).
I can get the mesh generated and the fluids fields set etc however when I solve my liquid seems to drain out the bottom of the domain even though it is a wall. Could someone tell me the boundary types that I should be using for inlet, outlet and the walls for files such as alpha, p and u? The idea being that I can visualise the wave pattern and calculate the resistance force on the block before moving onto more complex geometries. I am using openfoam 1.6 Thanks in advance |
Give use some more details on your work.
Are you doing 2D or 3D simulations? Tell us which boundary conditions you have used so far. |
