Home > Forums > OpenFOAM
Time in OpenFOAM
Old   December 16, 2009, 22:37
Red face Time in OpenFOAM
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
In steady state simulations the time really isnt important. Basicaly your best solution is the most recent time stamp.
But when you get into time dependent simulations how do you get all of your time steps to be of equal accuracy?
Fluent would let you define the accptable amount of error per time step and would itterate that timestep until it was within range then moved on to the next one.
How does OpenFOAM go about this? Is it different for each solver?
Thanks!
ericnutsch is offline   Reply With Quote
Old   December 17, 2009, 01:00
Alberto Passalacqua
Thanks!
In unsteady solvers based on the PISO algorithm you do not have such an approach. If you use an adaptive time step, the step size is controlled by the CFL condition. You assume implicitly that the time step is small enough to ensure convergence and accuracy.
In transient solvers using the PIMPLE/unsteady SIMPLE approach you can specify a number of sub-iterations per time step.
In all the cases, there is no explicit control on the residuals, which however can be easily added. Residuals can be retrieved easily defining a "solverPerformance" object
lduMatrix::solverPerformance sp;
then when you solve the equation just write
sp = solve ( /* Your equation here */);
and you will be able to retrieve the initial (you want the initial, not the final residual of the linear solver for your purpose) residual of each iteration with
sp.initialResidual()
Repeating this for all the equations you solve, and with some modification to the code you want to use, you can reproduce what is done in commercial codes
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   December 17, 2009, 13:48
Eric Nutsch
Using the CFL condition to set the delta T seems like a good approach.
(U * deltaT)/deltaX < Courant <1
So for 10m/s and 1mm resolution, the time step must be less than 0.0001. Simple enough. So if i am going to solve a transient problem, do i have to initialize with a steady state solution? or do i just disregard the first 50 or so time steps?
Wikipedia also presents a two-dimensional equation. Does this equation need to be used for 2D problems or can I just use the magnitude (a^2 + b^2 = c^2) of the vectorial flow in the 1D equation?
I will try out your residual control code as I get further along in my project. Why do i want to view the initial residuals instead of the final ones?
Thanks for your post Alberto, it was most helpful!
Old   December 18, 2009, 08:12
Alberto Passalacqua
An unsteady simulation is, after a sufficient time, independent from the initial condition, so you can use what you prefer. If your case admits a steady state, you should probably use a steady solver, if it doesn't, start from a physically sound initial condition, and start averaging when the flow is completely developed if you need averaged profiles.
Just set the maximum Courant number you want to use, and turn the adaptive time step on
Because you want the initial residual to become smaller in each time step, since if this happens, it means you are getting closer to your solution.
The "final" residual returned by solverPerformance is very small anyway, since it is the residual the linear solver returns after solving the linear system.
You're welcome
Best,
Alberto Passalacqua
Old   December 18, 2009, 19:52
Default using adaptive time step?
Eric Nutsch
How do i "turn the adaptive time step on "?
I read this forum: Adaptive timestepping
It said to include readTimeControls.H, CourantNo.H and setDeltaT.H, but it was a little brief. Turning it "on" sounds a lot more friendly. Could you please explain.
Thanks again for your help Alberto!
Old   December 18, 2009, 20:02
Alberto Passalacqua
What solver are you using?
Best,
Alberto Passalacqua
Old   December 18, 2009, 23:52
Eric Nutsch
Though i have not started this simulation yet, i currently plan to use pisoFoam.
I am planning on using a rotating reference frame so my solver may change in order to accommodated that aspect.
Lots of variables to consider when your getting started
Thanks again Alberto!
Old   December 19, 2009, 00:30
Alberto Passalacqua
To "turn" the adaptive time step on in pisoFoam add
adjustTimeStep  yes;
maxCo           1;
maxDeltaT       1e-03;
in controlDict.
Of course the values of Co (Courant number) and the maximum time step are examples.
Best,
Alberto Passalacqua
Old   December 19, 2009, 00:39
Eric Nutsch
Thanks for all the excellent help Alberto!
I will give your code a try
Thread Tools
Trackbacks are On
Time step size and max iterations per time step pUl| FLUENT 31 August 21, 2015 04:46
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
