Please help - error after recompiling thermophysical models |
December 31, 2009, 10:21 |
Axel Tietjen
Rep Power: 16 |
Dear Foam users,
I have just 4 weeks left to finish my diploma thesis about OpenFoam and it seems that I accidently ruined my OpenFOAM installation. Running short of time, I hope someone can give me a quick solution to fix the problem. But here is the whole story: After I got a bit to often terminated solutions with error-messages like "maximum number of equations exceeded", I wanted to try to change that value in the source files. I found that value in /home/axel/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels/specie/lnInclude/specieThermo.C and changed it. To "activate" those modifications, the code must be compiled again (I hope I'm at least right in this point), so I executed wmake libso specie as I found that command in the /src/thermophysicalModells/Allwmake file. Now there is allways the following error message when I execute a rhoPisoFoam Simulation: Creating turbulence modelIt's the same when I use kEpsilon turbulence model, but when I use for example icoFoam, which doesn't use a turbulence model it runs without error. My first Idea was to recompile the turbulence files, too. With no success. Then I took back all modifications and recompiled everything in the original state. Didn't help, too. As anyone some ideas, how I can repair my OpenFOAM installation? I'd appreciate any hints. Thanks, (and btw a happy new year!) Axel |
January 5, 2010, 08:24 |
unsolved but obsolete
Axel Tietjen
Rep Power: 16 |
Hello to everyone,
the problem is still unsolved, but since I re-installed my computer and OpenFOAM, the error doesn't appear anymore, of course. I've learned my lesson, and from now on, I'll never touch the source-files again. greetings Axel |
change source files, maximum number, recompile, stack violation |
Display Modes | |
Two-fluid models vs mixture models for bubbly flows | Hansong Tang | Main CFD Forum | 6 | December 8, 2009 03:21 |
MODELS | Murthy V N | FLUENT | 0 | February 9, 2008 01:48 |
informaiton about k-omega models | krisreddi | CFX | 2 | August 10, 2005 06:53 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 15:39 |
CFD models | Xie | Main CFD Forum | 0 | April 18, 2002 13:48 |
