icoFsiFoam install OpenFOAM-1.6
Old   December 26, 2009, 06:30
Default icoFsiFoam install OpenFOAM-1.6
yusuke
yukeone is on a distinguished road
Hi everybody,
I'm yukeone of a open beginner.
It was installed in order to use icoFSIFoam solver in OpenFOAM-1.6.
Then the following error occurred.
SOURCE=icoFsiFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/dynamicFvMesh/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/dynamicMesh/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/tetDecompositionFiniteElement/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/tetDecompositionMotionSolver/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoFsiFoam.o
icoFsiFoam.C:38:28: error: tetFemMatrices.H: No such file or directory
icoFsiFoam.C:39:28: error: tetPointFields.H: No such file or directory
icoFsiFoam.C:40:30: error: faceTetPolyPatch.H: No such file or directory
icoFsiFoam.C:41:39: error: tetPolyPatchInterpolation.H: No such file or directory
icoFsiFoam.C:42:42: error: fixedValueTetPolyPatchFields.H: No such file or directory
In file included from icoFsiFoam.C:55:
createStressMesh.H: In function ‘int main(int, char**)’:
createStressMesh.H:18: error: no matching function for call to ‘Foam::volPointInterpolation::volPointInterpolatio n(Foam::fvMesh&, Foam:ointMesh&)’
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/volPointInterpolation.H:89: note: candidates are: Foam::volPointInterpolation::volPointInterpolation (const Foam::fvMesh&)
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/volPointInterpolation.H:74: note: Foam::volPointInterpolation::volPointInterpolation (const Foam::volPointInterpolation&)
In file included from icoFsiFoam.C:59:
readCouplingProperties.H:66: error: ‘tetPointVectorField’ was not declared in this scope
readCouplingProperties.H:66: error: ‘motionU’ was not declared in this scope
readCouplingProperties.H:67: error: expected type-specifier before ‘tetPointVectorField’
readCouplingProperties.H:67: error: expected `>' before ‘tetPointVectorField’
readCouplingProperties.H:67: error: expected `(' before ‘tetPointVectorField’
readCouplingProperties.H:67: error: expected primary-expression before ‘>’ tokenreadCouplingProperties.H:69: error: ‘tetPointVectorField’ cannot appear in a constant-expression
readCouplingProperties.H:72: error: no matching function for call to ‘Foam::fvMesh::lookupObject(const char [8]) const’
readCouplingProperties.H:73: error: expected `)' before ‘;’ token
readCouplingProperties.H:76: error: ‘fixedValueTetPolyPatchVectorField’ was not declared in this scope
readCouplingProperties.H:76: error: ‘motionUFluidPatch’ was not declared in this scope
readCouplingProperties.H:77: error: ‘fixedValueTetPolyPatchVectorField’ cannot appear in a constant-expression
readCouplingProperties.H:82: error: ‘tetPolyPatchInterpolation’ was not declared in this scope
readCouplingProperties.H:82: error: expected `;' before ‘tppi’
In file included from icoFsiFoam.C:82:
setMotion.H:22: error: ‘tppi’ was not declared in this scope
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:8: warning: unused variable ‘momentumPredictor’
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:11: warning: unused variable ‘transonic’
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readPISOControls.H:14: warning: unused variable ‘nOuterCorr’
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readTimeControls.H:40: warning: unused variable ‘maxCo’
/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readTimeControls.H:43: warning: unused variable ‘maxDeltaT’
make: *** [Make/linux64GccDPOpt/icoFsiFoam.o] Error 1
How should it be done to put out erorr?
Can't I have advice?
Thank you.
yukeone is offline   Reply With Quote
Old   January 15, 2010, 04:14
FG_HSRM is on a distinguished road
Hello yusuke!
Did find a way to handel this problem?
Does anybody know what problems have to be solved, so that I can use this solver with OF 1.6?
Thanks a lot for your help!
Regards
FG_HSRM is offline   Reply With Quote
Old   June 29, 2010, 04:37
Karl Jacob Maus
karlmaus is on a distinguished road
Easy fix: Get 1.5-dev.
Hard fix: Write FEM-routines/classes for 1.6...
See
http://www.cfd-online.com/Forums/ope...oam-1-6-a.html
karlmaus is offline   Reply With Quote
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 00:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 04:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 09:04
