interFoam error
Hello foamers ;
I'm trying to solve free surface problem using interFoam solver after setting fields and specify the boundary conditions alpha1 , p , and U i executed the interFoam solver and got that error ; Create time Create mesh for time = 0 Reading g Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /home/openfoam1/Desktop/damBreakTest/system/fvSolution::PISO from line 55 to line 60. From function void Foam::setRefCell ( const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 112. FOAM exiting thank you very much |
From the error u can say that you have mentioned pRefValue and pRefPoint in the PISO loop in the system/fvSolution dictionary. adding both in the PISO loop u can solve the problem.
i did , i put pRefPoint 0 ; pRefValue 0 in the PISO loop and got again an error Create time Create mesh for time = 0 Reading g Reading field p Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar time step continuity errors : sum local = 3.00873e-19, global = -1.87935e-19, cumulative = -1.87935e-19 --> FOAM FATAL ERROR: incompatible dimensions for operation [pcorr[-1 3 -1 0 0 0 0] ] == [div(phi)[0 0 -1 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&) in file /home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/fvMatrix.C at line 1219. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so" #2 void Foam::checkMethod<double>(Foam::fvMatrix< double> const&, Foam::DimensionedField<double, Foam::volMesh> const&, char const*) in "/home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/interFoam" #3 Foam::tmp<Foam::fvMatrix<double> > Foam::operator==<double>(Foam::tmp<Foam:: fvMatrix<double> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/interFoam" #4 main in "/home/openfoam1/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/interFoam" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Aborted |
sorry, it is pRefCell not pRefPoint. You can check the variable declarations in createFields.C in interFoam source directory.
Regarding pcorr error, have a look at the "continuityErrs.H" file in source directory. What I feel from the error, you might messed up with dimension, try to see one-to-one matching with tutorial case, if you are doing for the first time. All the best. Regards Santosh... |
yes i do that for the first time ,, I'm trying to simulate the behavior of a water droplet on a hydrophobic flat plate under wind drag and the plate have to rotate
how can i make the flat plat rotates, is it possible in openfoam ? thank you |
Yeah u can model plate rotation using derived BC, i.e, rotatingWallVelocity.
Santosh. |
I am kind of new user in openfoam. I want to simulate such problem that you mentioned in forum( simulating a droplet on hydrophobic surface). would you please help to simulate this.or can u send me your setup..I would be so grateful if you help me through this . thanks Mehran Quote:
Regarding the error:
The solver needs to know what and where the reference pressure is. Add the following to your fvsolution file: PISO { ... pRefPoint (-0.081 -0.0257 8.01); pRefValue 1e5; } |
