grid analysis
hi guys,
i have a question about grids for open foam. i have created grids which are represented both in polymesh and in vtk format. the grids are properly constructed as the openfoam simulation works fine and the residuals converge. the thing i want is to analyze my grids. to be more precisly, i want to gain information about the maximum/minimum/average angles, edge lengths, edge length ratio etc. is there a simple way to solve this problem? i would prefer a solution which works also on windows (as paraview does), since i havent installed linux on my notebook so far. thank you very much for your help! best regards |
Simply run the checkMesh utility - it will tell you all you need to know.
Enjoy, Hrv |
It is nice to use for small problems/learning and you just need a notebook capable booting from usb. read more about OF on Slax here http://www.cfd-online.com/Forums/ope...lax-based.html greetings elvis |
