Question about finding force in OF 1.7.1 using interFoam
Old   October 29, 2010, 17:00
Question Question about finding force in OF 1.7.1 using interFoam
Angela Wang
Angela Wang is on a distinguished road
Send a message via MSN to Angela Wang
I added the following to the controlDict file.
functions
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 1;
patches (hydrofoil);
pName p_rgh;
UName U;
log true;
rhoName rhoInf;
rhoInf 1000;
CofR (0.249048674523 -1.034 0);
forceCoeffs
type forceCoeffs;
outputInterval 1;
pName p_rgh;
UName U;
log true;
rhoName rhoInf;
rhoInf 1000;
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0.249048674523 -1.034 0);
magUInf 1.77653;
lRef 1;
Aref 1;
Angela Wang is offline   Reply With Quote
Old   October 29, 2010, 17:02
Angela Wang
And the code responded as:
--> FOAM FATAL IO ERROR:
keyword nu is undefined in dictionary "/handel3/lwangk/OpenFOAM/lwangk-1.7.1/run/selfcase/naca0012_oct28_nodamping/constant/transportProperties"
file: /handel3/lwangk/OpenFOAM/lwangk-1.7.1/run/selfcase/naca0012_oct28_nodamping/constant/transportProperties from line 20 to line 62.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
I googled for the solution and recompiled the libforces.so according to
http://www.cfd-online.com/Forums/ope...es-of15-8.html
#111
I copied /OpenFOAM/OpenFOAM-1.7.1/src/postProcessing/functionObjects/forces to a
"forcesInter" folder under
/OpenFOAM/OpenFOAM-1.7.1/src/postProcessing/functionObjects/.
And I modified
everything (filename and contents in all files) from "forces" to
"forcesInter" and modified in the file "forcesInter.C"
line 106 to nu(transportProperties.lookupEntry("phase1",false, false).dict().lookup("nu"));
//modified for finding the main nu
But the compilation failed. Any one can help??
Old   October 29, 2010, 17:05
Angela Wang
My error is :
Make/linux64GccDPOpt/forces.o: In function `Foam::tmp < Foam::GeometricField < Foam::SymmTensor < double >, Foam::fvPatchField, Foam::volMesh > > Foam::dev < Foam::fvPatchField, Foam::volMesh >(Foam::tmp < Foam::GeometricField < Foam::SymmTensor<double >, Foam::fvPatchField, Foam::volMesh > > const&)':
forces.C.text._ZN4Foam3devINS_12fvPatchFieldENS_ 7volMeshEEENS_3tmpINS_14GeometricFieldINS_10SymmTe nsorIdEET_T0_EEEERKSA_[Foam::tmp < Foam::GeometricField < Foam::SymmTensor<double >, Foam::fvPatchField, Foam::volMesh > > Foam::dev < Foam::fvPatchField, Foam::volMesh >(Foam::tmp < Foam::GeometricField < Foam::SymmTensor < double >, Foam::fvPatchField, Foam::volMesh > > const&)]+0x45a): undefined reference to `Foam::calculatedFvPatchField < Foam::SymmTensor < double > >::typeName'
Make/linux64GccDPOpt/forcesInter.o: In function `Foam::forcesInter::rho() const':
forcesInter.C: (.text+0xedd): undefined reference to `typeinfo for Foam::fvMesh'
forcesInter.C: (.text+0x101c): undefined reference to `Foam::calculatedFvPatchField<double>::typeName'
forcesInter.C: (.text+0x11c5): undefined reference to `Foam::fvMesh::typeName'
Make/linux64GccDPOpt/forcesInter.o: In function `Foam::forcesInter::devRhoReff() const':
forcesInter.C.text+0x1374): undefined reference to `typeinfo for Foam::compressible::RASModel'
forcesInter.C: (.text+0x14bc): undefined reference to `typeinfo for Foam::incompressible::RASModel'
forcesInter.C: (.text+0x1678): undefined reference to `typeinfo for Foam::compressible::LESModel'
forcesInter.C: (.text+0x17ac): undefined reference to `typeinfo for Foam::incompressible::LESModel'
forcesInter.C.text+0x191c): undefined reference to `typeinfo for Foam::basicThermo'
forcesInter.C: (.text+0x1afc): undefined reference to `typeinfo for Foam::singlePhaseTransportModel'
Make/linux64GccDPOpt/forcesInter.o: In function `Foam::forcesInter::calcForcesMoment() const':
forcesInter.C: (.text+0x2285): undefined reference to `Foam::fvMesh::Sf() const'
forcesInter.C: (.text+0x23ee): undefined reference to `Foam::fvMesh::C() const'
forcesInter.C: (.text+0x2c5f): undefined reference to `Foam::fvMesh::Sf() const'
forcesInter.C.text+0x2e26): undefined reference to `Foam::fvMesh::C() const'
Make/linux64GccDPOpt/forcesInter.o: In function `Foam::forcesInter::read(Foam::dictionary const&)':
forcesInter.C: (.text+0x453c): undefined reference to `typeinfo for Foam::fvMesh'
forcesInter.C: (.text+0x4fe1): undefined reference to `Foam::fvMesh::typeName'
Make/linux64GccDPOpt/forcesInter.o: In function `Foam::forcesInter::forcesInter(Foam::word const&, Foam:bjectRegistry const&, Foam::dictionary const&, bool)':
forcesInter.C: (.text+0x51f1): undefined reference to `typeinfo for Foam::fvMesh'
forcesInter.C: (.text+0x5481): undefined reference to `typeinfo for Foam::fvMesh'
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
Old   October 30, 2010, 07:28
Alton Luder III
sleepdeprivation is on a distinguished road
Yea I'm having the same problem. It seems forces library doesn't have a way to compensate for multiple fluids. I haven't, however, look deep enough into the functions to know if the RAS and LES formulations take into account multiple fluids.
sleepdeprivation is offline   Reply With Quote
Old   November 2, 2010, 02:49
colinB is on a distinguished road
Hi
I have the same version of OF like you (171) and I get everything running
in interFoam with the ras turbulence model.
Actually the message stated quite clear that you however did not specify
nu in the transportProperties file.
so for example in one of my files after the header there are the following
lines:
transportModel      Newtonian;
nu                       nu [0 2 -1 0 0 0 0]  1e-06;
and now the same for each phase with some other specifications.
I guess this you checked already, as it was a hint from the error message.
Anyway, I compared my forces attachment in the controlDict File and could
indeed identify some differences. So here my attachment so you can
check:
functions
            forces
                  type forces;
                  outputControl        timestep;
                  outputInterval 1;
                  patches (here_could_be_your_patch);
                  rhoInf   1000;
                  nuInf 1e-06;
                  CofR (0 0 0);
             forceCoeffs
                  type forceCoeffs;
                  outputInterval 1;
                  rhoInf 1000;
                  nuInf 1e-06;
                  CofR (0 0 0);
                  liftDir (0 0 1);
                  dragDir (-1 0 0);
                  pitchAxis (0 1 0);
                  magUInf -8.0;
                  lRef 1;
                  Aref 1;
I hope that helps
regards
Colin
colinB is offline   Reply With Quote
Saffman Lift Force: confused CFD_MAN FLUENT 5 September 9, 2010 04:51
Question on turbulent dispersion force in momentum Emmery FLUENT 0 December 12, 2007 10:31
Simple rotational force question Mike Main CFD Forum 1 September 12, 2007 12:08
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 18:26
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
