Bounding turbulence values
1 Attachment(s)
How to change the bounding values for the turbulence parameters such as "k" and "Omega"? My simulation crashes due to "omega" becoming very low of the order of 1e-18. How can i overcome this problem. I am using K-omega + SST model. ThnX!! varun |
Hi Varun,
I am facing the same problem as yours. I am using the k-w SST turbulence model and during iteration, I have both bounding k and omega. The min and max values are between 1e-6 to 1e+6. FYI, I applied boundary layers on my car (it's an external aerodynamics of car in a wind tunnel case) - about 10 layers and the y+ values are between 0 to 100 (average of about 30). I think it is because of my y+ values but I am not really sure. If it's true, then should I increase my y+ values by making the layers nearest to wall to be thicker? Could anyone help me on this? Regards, Ayu |
I had a similar problem of very extreme values of k and epsilon (it was a wind simulation case). Then I tried reducing the relaxation factors for k and epsilon. I gave very low value like 0.01. Of course the simulation took a long time, but the bounding values did not go to extremes. Try it out and let me know. Cheers, Balakrshnan Ramakrishnan |
