Placing a heat source in an airconditioned room
Old   January 22, 2010, 16:59
Default Placing a heat source in an airconditioned room
Robin Gilbert
robingilbert is on a distinguished road
Hello guys,
I was trying to simulate multiple heat sources inside an airconditioned room (which means that there is an inlet and an outlet for air in the room). i tried using rhoPimpleFoam but i doubt if the results are right. I want to study the flow of heat from the heat sources to its surroundings.
What solver should i use? is rhoPimpleFoam sufficient?
robingilbert is offline   Reply With Quote
Old   January 23, 2010, 15:13
Robin Gilbert
it would be really helpful if somebody could answer my question.
Thanks
Old   January 24, 2010, 06:50
James Nally
jnally is on a distinguished road
I would check out the heat transfer solvers, eg buoyantPisoFoam
all of them can be found in "OpenFOAM/OpenFOAM-1.6/applications/solvers/heatTransfer/" and see if there is something there which suits your needs, the main source file will have a description of the solver near the top.
jnally is offline   Reply With Quote
compressible flow, heat source, hvac, rhopimplefoam
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
