units in OpenFOAM
Like Tree4Likes
  • 2 Post By megacrout
  • 1 Post By akidess
  • 1 Post By fabian_roesler
Old   July 15, 2011, 05:44
Default units in OpenFOAM
Tibo
megacrout is on a distinguished road
I am getting confused about the units used in OpenFOAM for some parameters, especially p and phi.
1. p has to be given with units m2/s2 in simpleFoam (which actually are the units of p/rho) but with the usual units kg/m/s2 in reactingFoam for example.
I´m pretty sure this has something to do with incompressibility but I am not quite sure and I don´t get why it is programmed this way.
2. phi is rho.U (e.g. User Guide 1.7.1 p.115 or 2.0.0 p.118), right? It thus should have units kg/m2/s but has units m3/s in the time step folders. why is that so?
This question might result from a bad understanding of what phi is. Complementary information about it too would be appreciated.
Thanks for your help.
Tibo
rafa13 and hulli like this.
megacrout is offline   Reply With Quote
Old   July 15, 2011, 07:14
akidess's Avatar
Anton Kidess
1. With constant density, you can divide the entire equation with rho and you will end up with a modified pressure, and thus the "uncommon" units.
2. phi is U * Sf (velocity times surface area) in all the solvers I worked with.
rafa13 likes this.
Old   July 18, 2011, 05:37
Tibo
Hi Anton,
Thanks for your answer.
I´m a bit confused though. As I mentioned, phi is defined as rho * U in the User Guide (p.115 or p.118). Does that mean the definition varies depending on the situation studied or the solver used?
Best regards.
Tibo
Old   July 19, 2011, 05:44
Smile Phi units
Fabian Roesler
fabian_roesler is on a distinguished road
in simpleFoam you assume constant density.
phi = rho*U*Sf [kg/s] in the convective term
as rho is constant you can divide the whole equation by rho as akidess posted before. And so you get
phi = U*Sf [m³/s]
Regards
Fabian
rafa13 likes this.
fabian_roesler is offline   Reply With Quote
Old   July 19, 2011, 08:04
Tibo
All right!
Crystal clear.
thx
phi, pressure, units
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
