February 9, 2010, 03:52 |
Compiling buoyantPisoRadiationFoam
Maruthamuthu Venkatraman
Hello Foamers,
I am quite new to compile the solvers in OpenFoam for new applications. So if there is any flaws in my compilation let me know. I tried to make a copy of BuoyantPisoFoam in my user directory and include radiation for the same.The application is created with two warnings. Give me your comments. Thanks. Compilation Message SOURCE=buoyantPisoFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasin g -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRep ository -ftemplate-depth-40 -I../buoyantPisoFoam -I/usr/local/OpenFOAM/OpenFOAM- 1.6.x/src/thermophysicalModels/basic/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1. 6.x/src/thermophysicalModels/radiation/lnInclude -I/usr/local/OpenFOAM/OpenFOAM- 1.6.x/src/turbulenceModels/compressible/turbulenceModel -I/usr/local/OpenFOAM/Op enFOAM-1.6.x/src/finiteVolume/cfdTools -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/ finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/ OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnI nclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/buoyantPisoFoam.o /usr/local/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/readPISOControls.H : In function ‘int main(int, char**)’: /usr/local/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/readPISOControls.H :11: warning: unused variable ‘transonic’ /usr/local/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude/readPISOControls.H :14: warning: unused variable ‘nOuterCorr’ g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parame ter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I../buoyantPisoFoam -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalMode ls/basic/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/thermophysicalModels /radiation/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/turbulenceModels/c ompressible/turbulenceModel -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolum e/cfdTools -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnI nclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/usr/lo cal/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64G ccDPOpt/buoyantPisoFoam.o -L/usr/local/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPO pt \ -lmeshTools -lbasicThermophysicalModels -lspecie -lradiation -lcomp ressibleRASModels -lcompressibleLESModels -lfiniteVolume -lOpenFOAM -liberty -ld l -lm -o /home/muthu/OpenFOAM/muthu-1.6.x/applications/bin/linux64GccDPOpt/buo yantPisoRadiationFoam --------------------------------------------------------------------------------------------------- Changes made h.Eqn.H { fvScalarMatrix hEqn ( fvm::ddt(rho, h) + fvm::div(phi, h) - fvm::laplacian(turbulence->alphaEff(), h) == DpDt + radiation->Sh(thermo) // added by me ); hEqn.relax(); hEqn.solve(); thermo.correct(); radiation->correct(); } buoyantPisoFoam.C \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "basicRhoThermo.H" #include "turbulenceModel.H" #include "fixedGradientFvPatchFields.H" #include "radiationModel.H" // added by me // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "readGravitationalAcceleration.H" #include "createFields.H" #include "createRadiationModel.H" // added by me #include "initContinuityErrs.H" #include "readTimeControls.H" #include "compressibleCourantNo.H" #include "setInitialDeltaT.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.run()) { #include "readTimeControls.H" #include "readPISOControls.H" #include "compressibleCourantNo.H" #include "setDeltaT.H" runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; #include "rhoEqn.H" #include "UEqn.H" #include "hEqn.H" // --- PISO loop for (int corr=0; corr<nCorr; corr++) { #include "pEqn.H" } turbulence->correct(); rho = thermo.rho(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // Option file : EXE_INC = \ -I../buoyantPisoFoam \ -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \ -I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \ -I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel \ -I$(LIB_SRC)/finiteVolume/cfdTools \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -lmeshTools \ -lbasicThermophysicalModels \ -lspecie \ -lradiation \ -lcompressibleRASModels \ -lcompressibleLESModels \ -lfiniteVolume // |
February 9, 2010, 06:11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings maruthamuthu_venkatraman,
I remember seeing those two warnings when we build the original version, so it's nothing new there. They just mean that those two variables are defined but never used. As for the modification, I can't say anything about it, since I don't have experience in merging solvers Best regards, Bruno Santos |
February 9, 2010, 09:46 |
Thank You!
The solver runs without any problems. However i need to make some more validations before to say anything. I want to check the wallHeatFlux but i dont know how to use that utility in OpenFOAM 1.6. Regards |
error msg when compiling user fortran | Ollimarc | CFX | 0 | March 13, 2008 18:16 |
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 | sponiar | OpenFOAM Running, Solving & CFD | 3 | February 26, 2008 06:31 |
Problem compiling OpenFOAM on AIX 53 | haunschmid | OpenFOAM Installation | 1 | October 17, 2006 12:58 |
some problem about compiling Nektar | ztdep | Main CFD Forum | 0 | July 30, 2005 09:43 |
Discussing UDF and C++ Compiling | Big Stone | FLUENT | 9 | April 12, 2004 15:07 |
