March 3, 2010, 09:34 |
DirectMapped
Primoz Ternik
Rep Power: 17 |
Hi Foamers,
I need a help on the following - I would like to calculate fully developed (from inlet to outlet) channel flow (Hagen-Poiseuille) of non-Newtonian fluid for a given mass flow rate (actually for a given average velocity, since I know the channel height and density of a fluid). Is the DirectMapped type of boundary condition for a velocity the only choice for this (for Carreau-Yasuda non-Newtonian fluid there is no theoretical experssion for fully developed velocity profile)? If so, what is the meaning of offset (0.05 0 0) (I looked for this example in oodles/pitzDailyDirectMapped tutorial? Thanks in advance! Cheers, Primoz |
March 3, 2010, 09:45 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Primoz
The offset-vector states in what direction and how far away from the given boundary patch data should be extracted and mapped back onto the given patch. Best regards, Niels |
March 3, 2010, 10:05 |
#3 | |
Primoz Ternik
Rep Power: 17 |
thank you! So, offset (1 0 0) means that flow field (e.g. velocity) is mapped from "plane" that is 1 unit far away from inlet in x-direction? Enjoy, primoz |
March 3, 2010, 10:20 |
Rep Power: 37 |
Exactly!
Have fun. |
March 3, 2010, 13:50 |
Primoz Ternik
Rep Power: 17 |
Hi Niels,
sorry, but I have some "issues" with directMapped method. I have calculated (with nonNewtonianIcoFoam) flow of a Newtonian fluid in a channel (L=2, H=1) using your suggestion. The velocity looks fine (fully developed from inlet to outlet) but the pressure looks "strange" - I would expect to get the linear pressure variation from inlet to outlet (theoretical pressure drop=2.4Pa), but the situation is quite different (please see attached figures). Can you (or someone else) make any comment, suggestions... I hope that I am doing something wrong, rather than blame the OpenFoam. For that I have also attached my case. enjoy, Primoz |
March 3, 2010, 15:04 |
Rep Power: 37 |
Hi Primoz
Could you please tell me what solver you are using? I might have an idea. Best regards, Niels |
March 3, 2010, 15:16 |
Primoz Ternik
Rep Power: 17 |
March 3, 2010, 16:41 |
Rep Power: 37 |
Hi
It was something else than I suspected, however I found out that the error lies with the use of CrankNicholson. Using either Euler or backward yielded good results. You might consider reporting it as a bug in the CrankNicholson. At least it is unsatisfactory that the time scheme has such a significant effect on the result, e.g. from right to wrong. Best regards, Niels |
March 3, 2010, 17:27 |
#9 | |
Primoz Ternik
Rep Power: 17 |
thank for your tip! I will run some tests tomorrow (using all three time schemes), document them well and put results on-line (on forum)! One last question - do you think that the "plane" of mapping (offset value) influences results (time evolution of flow in a straight channel)? Now I was mapping from the middle of a channel and I wonder if mapping from some other axial position (e.g. closer to inlet or outlet) would yield different results?! Cheers, Primoz |
March 4, 2010, 01:24 |
#10 |
Rep Power: 37 |
Good morning
Well, I do not think that the final steady-state solution will be affected by the length of the mapping zone, however the length will most certainly affect the necessary simulation time as a short zone will require longer simulation time than a longer one. I you at some point is going to consider turbulence, the length of the mapping zone become important for the final result, at least for LES, however as long as you are in the laminar regime, there are no issues with respect to "result as a function of mapping length". Have a good day, Niels |
March 4, 2010, 08:34 |
#11 | |
Primoz Ternik
Rep Power: 17 |
thank you for your time and explanations! I have just finished a study with all three differencing schemes. Results are as expected (regarding your previous post) - Euler and Backward differencing schemes yield good results, while Crank Nicholson ... See attached figures for the pressure drop (PressureDrop_Backward.png, PressureDrop_Euler.png, PressureDrop_CrankNicholson.png) and time evolution of centreline velocity (VxCentreline_TimeDiffScheme.pdf)! Please note, that the theoretical pressure drop for this case (at fully developed flow conditions) is 2.4Pa and the pressure varies (reduces) linearly with axial position! In adition, I have also tested (possible) influence of "mapping plane" position - according to your post, there is no influence of offset value on time evolution of centreline velocity (see attached figure - VxCentreline_OffsetValue.pdf). Thank you again! Enjoy, Primoz |
Cyclic vs ggi vs directMapped Patches | jens_klostermann | OpenFOAM Running, Solving & CFD | 33 | May 3, 2013 02:45 |
DirectMapped inlet + Experimental Inlet | Kr_kim | OpenFOAM Running, Solving & CFD | 0 | February 8, 2010 18:12 |
directMapped Method in OF-1.6 | Kr_kim | OpenFOAM Bugs | 2 | February 4, 2010 17:36 |
sample error in directMapped BC | matthias | OpenFOAM | 0 | November 13, 2009 17:00 |
directMapped BC in parallel | turnow | OpenFOAM | 0 | August 13, 2009 06:35 |
