problem with wallFunctions (kEpsilon model)
Hi everybody,
I was trying to simulate the flow around a wing by means of RANS model in OpenFOAM. The wallfunctions I'm trying to use for the kEpsilon gives me the following error: ----------------------------- gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type kqRwallFunction) on patch rear_wing of field k in file "/home/openfoam/Desktop/dinoOF/OFcase/3wing_SIMPLE/0/k" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 782. ---------------------------- I compared my testcase with some tutorials and they seems to be similar, so I cannot understand where is the problem?!?? thanks in advance dino |
Do you use a selfmade BC on the specific patch? I once got the same error message, which was easily fixed by specifying a "value uniform 0" entry, e.g.
wallHeated { //Tammo |
actually I'm using an already implemented BC, i.e. kqRwallFunction.
In the "k" file I'm using these settings for all the walls: rear_wing { type kqRwallFunction; value uniform 0.00735; } main_wing { type kqRwallFunction; value uniform 0.00735; } front_wing { type kqRwallFunction; value uniform 0.00735; } The strange thing is that if I change only for the first one (rear_wing) the value uniform from 0.00735 to 0 I get the following error: --------------- smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0187915, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0186828, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00799459, No Iterations 14 time step continuity errors : sum local = 8.85047e-07, global = 2.32762e-08, cumulative = 2.32762e-08 #0 Foam::error::printStack(Foam::Ostream&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 main in "/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception --------------------- and it remains also in the case i change the value for the other walls!!! what could be the reason?? thanks for the fast reply dino |
the error message tells you that you divide by zero somewhere, more specifically it is due to your setting at the rear_wing where you've set uniform 0 If you want a zero value there, just put a small non-zero value like 1e-10 to avoid division by zero there. Best, Florian |
do you use a solver for compressible flow? I think I already had the same error. For compressible calculations using rhoSimpleFoam "kqRWallFunction" should be replaced by "compressible::kqRWallFunction". Same for omega, so I think also for epsilon in your case. Just a guess. Regards |
for Florian:
if I set a very small value 1e-10, I get again the previous error (that I wrote in my first message). for cboss: it's an incompressible solver, SimpleFoam. I read in similar threads that the problem could be that the needed library is not loaded but comparing with another testcase that works I cannot see significative difference. If somebody wants to have a look I can upload the testcase on fileshare website. thanks to all for your availability dino |
Perhaps just a spelling error. According to your post you use "kqRwallFunction". Should be "kqRWallFunction". This produces the same error on my system.
Regards |
thanks cboss, you're right!
that's exactly the kind of error I never realize!! now it works great thanks to all |
I have the same problem when using twophaseEulerFoam,
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type epsilonWallFunction) on patch wall of field epsilon in file "/home/dft/OpenFOAM/dft-1.6/run/sg/0/epsilon" You are probably trying to solve for a field with a generic boundary condition. please help me ! |
Can you post your epsilon field?
dimensions [ 0 2 -3 0 0 0 0 ]; internalField uniform 0.05; referenceLevel 0; boundaryField { inlet { type fixedValue; value uniform 0.05; } wall { type epsilonWallFunction; value uniform 0.001; } outlet { type zeroGradient; } } Is there any problem? thanks |
In my fields for epsilon I have the following for the wall :
wall { type epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.0067; } you have to specify the 3 constants, hope this helps, Marine |
I reset the epsilon file, but it does not work. When i use the simpleFoam to caculate single phase flow, the wallfunction goes well. But in the simulation of two phase fow applying the twophaseeulerfoam , it displays the error.
