Boundary conditions - OpenFoam
I am a new user of OpenFoam and I am trying to set-up an under-expanded supersonic jet issuing into an open atmosphere.
I am using the rhoCentralFoam and it has an example for the a similar jet. Even though I can just copy the b.c. files (p,T and U) from the tutorial, I would like to better understand the various keywords in these files. For example, Jet_inlet { type totalPressure; value uniform 300000.0; p0 uniform 300000.0; U U; phi phi; rho none; psi psi; gamma 1.4; } I do not understand all the keywords here. what does p0, phi, and psi stand for ? I saw another example where all of the above keywords are not used ? Is there any documentation for what kind of keywords must be specified for what kind of boundary conditions ? Somebody please help. Thanks Vaidya |
Under-expanded jets - Boundary conditions help
Hello OpenFoamers
I need some help with the boundary conditions desperately. As I have mentioned in my previous post, I am trying to simulate an under-expanded jet. I have successfully simulated the same problem using Fluent. Now I am trying to use OpenFoam to compare the two solvers. (BTW, This is my first ever OpenFoam simulation.....) I am using rhoCentralFoam. It is a 2D grid I imported from Fluent using fluentMeshtoFoam. Here is the configuration. _________________________________ | free-stream | | | | wall_inlet | | |Outflow | | ! | ! jet_inlet axis | !-------------------------------------| Here is my 'p' file dimensions [1 -1 -2 0 0 0 0]; internalField uniform 10000.0; boundaryField { Jet_inlet { type totalPressure; value uniform 300000.0; p0 uniform 300000.0; U U; phi phi; rho none; psi psi; gamma 1.4; } wall_inlet { type zeroGradient; } axis { type zeroGradient; } outflow { type pressureTransmissive; value 10000.0 } top_boundary { type pressureTransmissive; value 10000.0 } } // ************************************************** *********************** // For the outflow and top_boundary (freestream) I have tried wave transmissive, zeroGradient,pressureTransmissive boundary conditions. But the simulation always crashes when the initial transient shock reaches the outflow. Here is my 'U' file dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Jet_inlet { type fixedValue; value uniform (319.2 0 0); } wall_inlet { type fixedValue; value uniform (0 0 0); } axis { type zeroGradient; } outflow { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } top_boundary { type zeroGradient; } } Here is my 'T' file { Jet_inlet { type totalTemperature; value uniform 300; T0 uniform 300; U U; phi phi; rho none; psi psi; gamma 1.4; } wall_inlet { type zeroGradient; } axis { type zeroGradient; } outflow { type zeroGradient; } top_boundary { type totalTemperature; value uniform 300; T0 uniform 300; U U; phi phi; rho none; psi psi; gamma 1.4; } } I must admit I am using the boundary conditions by looking at similar files in the rhoCentralFoam. I would sincerely appreciate if someone can tell me what is wrong with my set-up and also if possible tell me the meaning of the various keywords in the b.c files 'p','U' and 'T'. I can make an educated guess about some of them, but I would be more comfortable hearing that from experts out there... Please help Thanks Vaidya |
did you find a solution for the definition of psi, phi and U in totalPressure bc?
Creating New solver: for particle laden compressible jets
1 Attachment(s)
Hello OpenFoamers
I am a new user of OpenFoam and I am trying to set-up a particle-laden under-expanded supersonic jet issuing into an open atmosphere. Note, before I started OpenFoam, I ran fluent and got a converged solution for this problem Here are details of OpenFoam simulation: --------------------------------------- Solver: rhoCentralFoam Grid: axi-symmetric grid imported from Fluent using fluentMeshtoFoam I.C: I used the converged Fluent solution as initial condition for openFoam I managed to get a converged steady state solution for this problem without particles Particle laden jets: !---------------------------------- Now I am trying to run a particle-laden jets. Since the solver rhoCentralFoam does not have Lagrangian Particle Tracking in it, I realized that I have to create a new solver. I came across the icoLagrangianFoam solver which is basically a particle tracking solver for an incompressible flow. I found a nice tutorial "Tutorial icoLagrangianFoam/SolidParticle" by Auerlia Vallier (google for file name: Tutorial_icoLagrangianFoam_reviewed.pdf). I used that and managed to implement particle tracking in the rhoCentralFoam solver. I called this new solver rhoCentralParticleFoam This works well. But the problem is that the drag model in the original icoLagrangianFoam is a very simple constant drag model. I want to implement the standard drag model which is a function of particle Reynolds number based on the stokesian drag for spherical particles. Chapter 5 in the tutorial describes how to implement this drag model. When I did these changes I get compilation errors that I cannot comprehend. I admit that I don't know c++ and I am not able to figure out the exact problem. Can someone help me to fix these compilation errors ? I have attached a tar file which contains the codes I am using for this solver |
underexpanded jets
halo mr. sankarv
i am a new user of fluent! from ur post i learnt that u ve successfully simulated underexpanded jets in fluent. presently i am tryng to simulate the same!!! but i don get the results at alll can u just help me with the same!!!! could u say me wat sort of profile ahs to be put and the necessary boundary conditions to be specified in gambit and the NPR values to be put in the fluent!!!! i am desperately in nedd of ur help !!! |
Karthick
There is a paper by K. Senesh & V.Babu titled Numerical Simulation of Subsonic and supersonic jets, AIAA 2005-3095. In this paper they talk about the models, grids, initial conditions and boundary conditions for fluent. I followed this paper to setup my case in fluent. Please try to look up this paper. Quote:
Hi i am just starting in cfd... and am trying to simulate under-expanded jet using fluent. but my solution is not converging. can you please help me with it.
