new user
Old   March 24, 2010, 02:36
Smile new user
Peta
toffeepenny is on a distinguished road
Hello everyone..well im a novice to openfoam and I am trying to find some code of wind flow over a building(square)...Ive read heaps of papers and know its a tried and tested problem so im just wondering if there somewhere i can view some code...any help is appreciated. toffee
toffeepenny is offline   Reply With Quote
Old   March 24, 2010, 03:18
Elvis
elvis will become famous soon enough
take a look at http://www.openfoam.com/features/sta...bleFlowSolvers
, I guess one of these Solvers should do the work for you. So coding is not really nescessary, but make use of what is there correctly.
But do you know how you create your Geometrie? I mean CAD -> Iges/Step http://www.salome-platform.org/ or (STL=> SnappyHexMesh/discretizer http://www.discretizer.org/ Engrid http://engits.eu/cms/index.php?id=4)
or Blender or Blockmesh. I mean all the Preprocessing stuff, what you gonna use?
Opensource or commercial stuff
maybe http://www.symscape.com is the right thing for you it is commercial but you get results very fast. But I do not use it, nor do I get money for mention it
Elvis
elvis is offline   Reply With Quote
Old   March 24, 2010, 03:29
Peta
Thanks Elvis
Im using openfoam...just started on the tutorials in the user guide...so im looking at blockMesh and working my through the maze.....well it is for me.. just starting out! Im not from an engineering background and was hoping for a program already written for a flow over a cube so I could pick it apart and learn backwards...so to speak. Cheers
Old   March 24, 2010, 07:16
Elvis
Well blockmesh is not the best choice imho. I would only recommend it together with snappyhexmesh to build a "windtunnel" see the motorbike tutorial. Well i would take that as a starting point and raise the size of my tunnel for the house u want to simulate. maybe Blender should be used for STL file or try discretizer http://www.discretizer.org/node/9 it should be able to help you for what u want to do.
watch screencasts http://www.discretizer.org/node/14 or read the other material to get a feeling if is the right tool for u
...Im not from an engineering background
if you do not need simulations with real physical insight.
Take a look at Blender http://www.blender.org it has some a cfd simulation tool based on lattice bolzmann =>http://wiki.blender.org/index.php/Do...Physics/Fluids
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 18:37
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 01:31
CFX 10 User Routine NOT in Fortran Andre CFX 14 August 8, 2006 23:03
particle user routines Felix CFX 1 July 24, 2006 12:32
User Surface, Calculator Christian Bruzzese CFX 3 November 15, 2005 10:13
