MRFZones with two rotating zones
Like Tree2Likes
  • 1 Post By amgode
  • 1 Post By lukasf
Old   March 10, 2010, 23:31
Default MRFZones with two rotating zones
Benjamin
chemeng is on a distinguished road
Hello everybody! I have a mixer tank with two impellers in the same axis (0 1 0) at a different high. The solver only recognizes the first rotating zone. My MRFZones file is:
1
IMPELLER1ST
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches (SLIPWALL BAFFLE WALL CYCLIC);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 1 0);
omega omega [0 0 -1 0 0 0 0] 10.5;
2
IMPELLER2ND
I have tried to put in the IMPELLER2ND axis (0 -1 0) but it doesnt work. I have tried also a lot of differents forms but no one work.
I hope your suggestions. Thanks in advance!
chemeng is offline   Reply With Quote
Old   March 11, 2010, 00:57
amgode's Avatar
Amol
amgode is on a distinguished road
Could you please post the error also. That would be most helpful...
Try this...constant/MRFZones file:
2
IMPELLER1ST
IMPELLER2ND
Make sure that the the MRF zones are included in the constant/polyMesh/cellZones
Hope this helps !
Regards,
-- Amol
gozo likes this.
amgode is offline   Reply With Quote
Old   March 11, 2010, 01:10
Benjamin
I dont have any error, It just when I see the results only in the bottom part of the tank the flow field is rotating. In the upper part is static. I have tried the configuration that you have written and it doesnt work.
Any other possibility?
Old   March 11, 2010, 01:15
Benjamin
Ok, problem solved. you were right. I have just try again with your configuration and all is ok, sorry. Thank you very much!!
Old   March 30, 2018, 11:09
Default Two propellers simulation
Simone81 is on a distinguished road
I am running two propellers simulation, but only one propeller rotating! I am using pimpleDyMFoam (from propeller tutorial). This is my dynamicMeshDict file:
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
    cellZone        innerCylinderSmall1;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        origin      (0 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
    cellZone        innerCylinderSmall2;
        origin      (0.5 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
In the picture you can see only the second propeller is rotating. Any idea about what I am doing wrong?
Thank you !
Simone
File Type: jpg Screenshot from 2018-03-30 09-06-00.jpg (99.4 KB, 110 views)
Simone81 is offline   Reply With Quote
Old   April 3, 2018, 05:32
amgode's Avatar
Amol
Originally Posted by Simone81 View Post
        origin      (0 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
        origin      (0.5 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
Thank you !
Simone
In the dynamicMeshDict file above, it is not mentioned if the number of regions is one / two, I think that's what causing the problem.
Please check what input needs to be added to the dict file to tell the solver that there are two rotating zones present and not one.
Amol Gode
Old   August 4, 2018, 14:41
Default help
zeshan
Thecomebackkid is on a distinguished road
I need the same help, if anyone can shed some light on this
Thecomebackkid is offline   Reply With Quote
Old   October 26, 2018, 04:37
Andreas P.
AndreasPe is on a distinguished road
Originally Posted by Thecomebackkid View Post
[/U]
did you solve the problem? Which OpenFOAM version are you using? I also want to use multiple rotating zones but i can't find any reference on how to do it in OpenFOAM 5/6. In Foam-Extend-4.0 it is very easy with the turboFVMesh.
Thank you!
Andreas
AndreasPe is offline   Reply With Quote
Old   October 26, 2018, 07:42
zeshan
Originally Posted by AndreasPe View Post
Thank you!
Andreas
I think the way is to reference domain in separate patches but not sure since my simulation is not time marching properly yet. I have moving MRF's when running moveDynamicMesh however
im using v5 - I think - blue cfd 2017.
Old   July 9, 2019, 08:31
Mohamad
mhasif02 is on a distinguished road
        origin      (0 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
        origin      (0.5 0 0);
        axis        (0 1 0);
        omega       50; // rad/s
Thank you !
Simone
Look into the multiMotion solver.
Mohamad
mhasif02 is offline   Reply With Quote
Old   February 7, 2020, 05:36
Lukas Fischer
lukasf is on a distinguished road
I can recommend this link: https://openfoamwiki.net/index.php/P...dyMotionFvMesh
Let me share a working example of a dynamicMeshDict with 2 rotating zones:
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   multiSolidBodyMotionFvMesh;
//rotating cellZone and attributes
multiSolidBodyMotionFvMeshCoeffs
    rotating_r2 // this is a cellzone which has been created before the simulation starts
                origin      (0 -0.1 0); //origin (x y z) of rotation
                axis        (0 1 0); // axis of rotation (x y z)
                omega       6;  // rad/s
    rotating_r0 // this is a cellzone which has been created before the simulation starts
                origin      (1.38 -0.1 0); //origin (x y z) of rotation
                omega       -6; // rad/s
raj kumar saini likes this.
lukasf is offline   Reply With Quote
Old   March 2, 2022, 11:41
Lukas Fischer
I published CFD results using OpenFOAM and the moving mesh approach here:
https://asmedigitalcollection.asme.o...12A002/1120033
It worked well to predict the turbulent flow field downstream of active turbulence generators. In the paper we validated our CFD results with experimental data.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
                omega       6;  // rad/s
                omega       -6; // rad/s
Old   November 27, 2023, 03:47
Lukas Fischer
The applications of these moving mesh settings was published in this journal paper (open-access).
https://asmedigitalcollection.asme.o...nd-1D-Hot-Wire
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 08:25
Difference b/t rotating wall and rotating domain? Juno Kim CFX 2 February 20, 2007 20:08
about mutiple rotating reference frame lingo FLUENT 0 December 12, 2002 04:13
