-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Problem with rhoSimpleFoam (http://www.cfd-online.com/Forums/openfoam/73748-problem-rhosimplefoam.html)
mecbe2002 March 16, 2010 06:53
1 Attachment(s)
I am trying to simulate a simple Plane configuration. M=0.9 & alpha-1.
No.Of cells : 459487 (tetrahedral).
Solver : rhoSimpleFoam
I attached the "system" folder.
when i run the simulation i receive the following error.
idea@IDeA:~/OpenFOAM/idea-1.6/run/Problems/RAEplane$ rhoSimpleFoam
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : rhoSimpleFoam
Date : Mar 16 2010
Time : 16:15:11
Host : IDeA
PID : 13488
Case : /home/idea/OpenFOAM/idea-1.6/run/Problems/RAEplane
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model laminar
Starting time loop
Time = 1
#0 Foam::error::printStack(Foam::Ostream&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::DILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::DILUPreconditioner::DILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::lduMatrix::preconditioner::addasymMatrixCons tructorToTable<Foam::DILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/idea/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#8 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) in "/home/idea/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSimpleFoam"
#9 main in "/home/idea/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSimpleFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
Anyone please help me.
Regards
mecbe
:confused:
stawrogin March 18, 2010 16:26
Hi mecbe,
A so early crash often indicates and error in the internal field values at the start.
Make sure to use absolute pressure and absolute temperature. Also the turbulence properties in the internal field should be non-zero.
Maybe this helps
stawrogin
claco April 9, 2010 08:49
Hi all,
where can I check if absolute or relative pressure is used?
Moreover, if I want to use a reference pressure of 101325 [Pa], where have I to set it?
mecbe2002 April 11, 2010 00:54
You have to explore the code to see whether it uses absolute or relative pressure..
I am not sure about specifying free stream values..
Check this link. It may help
http://www.aero.polimi.it/freecase/?...:ONERA_M6_wing
Regards
mecbe
