-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   splitMesh Error (https://www.cfd-online.com/Forums/openfoam/73819-splitmesh-error.html)
robingilbert March 17, 2010 18:16
splitMesh Error
Hello guys,
I ran splitMesh on an internal surface and it worked fine. I want to run splitMesh on another surface which is surrounded by the previous surface. I tried running splitMesh but it gave the following error:
Create time
Create polyMesh for time = 0
Read 226 faces to split
--> FOAM FATAL ERROR:
Can not find faces using edge (61716 68018) on cell 168913
    From function meshTools::getEdgeFaces(const primitiveMesh&, const label, const label, label&, label&
    in file meshTools/meshTools.C at line 513.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  Foam::regionSide::otherFace(Foam::primitiveMesh const&, int, int, int) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/applications/bin/linux64GccDPOpt/splitMesh"
#3  Foam::regionSide::walkAllPointConnectedFaces(Foam::primitiveMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::HashSet<int, Foam::Hash<int> > const&) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/applications/bin/linux64GccDPOpt/splitMesh"
#4  Foam::regionSide::regionSide(Foam::primitiveMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::HashSet<int, Foam::Hash<int> > const&, int, int) in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/applications/bin/linux64GccDPOpt/splitMesh"
#5  main in "/home/robingilbert/OpenFOAM/robingilbert-1.6.x/applications/bin/linux64GccDPOpt/splitMesh"
#6  __libc_start_main in "/lib/libc.so.6"
#7  _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
Aborted
Please help me out. this is very important
