Impinging jet simulation error
1 Attachment(s)
I am trying to simulate an Impinging jet. I have created geometry and meshed it in Salome and transfered in the Openfoam using IdeasUnvToFoam. I am getting this error after few time iterations: Time = 0.205425 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0266363, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0300905, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0434508, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.913357, Final residual = 0.00844998, No Iterations 5 time step continuity errors : sum local = 1.88172e+57, global = 3.94684e+45, cumulative = 3.94684e+45 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.0502332, No Iterations 17 DILUPBiCG: Solving for k, Initial residual = 2.0615e-20, Final residual = 2.0615e-20, No Iterations 0 ExecutionTime = 588.83 s ClockTime = 589 s Time = 0.206338 DILUPBiCG: Solving for Ux, Initial residual = 0.436017, Final residual = 0.0316758, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.403818, Final residual = 0.0338512, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.491748, Final residual = 0.0305268, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 208.867, No Iterations 1001 time step continuity errors : sum local = 4.23244e+62, global = 1.42026e+59, cumulative = 1.42026e+59 #0 Foam::error::printStack(Foam::Ostream&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 main in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception Can someone please help me. I have attached my case with this message. thanks in advance regards jish |
Hi
This does not look right. Quote:
p GAMG |
Hello Linnemann,
I have tried to apply your changes in the fvsolutions, but its showing me a fatal error. Can you please tell me where to apply these changes? thanks /jish |
Further information,
I am using SimpleFoam to compute these and at high Re of 10000. /jish |
Hi it should be applied in you fvSolution file
are you using 1.6 or 1.5-dev? I dont remember if 1.6 supports the minIter/maxIter but you could try and comment these if it throws an error. Can you post the error since I don't have a whole lot to work with when I don't know the error. |
I am using OpenFoam 1.6. I tried to change the fvsolution as you mentioned but I got another error. *first full error which I got when I was trying to simulate is this: Time = 0.205425 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0266363, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0300905, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0434508, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.913357, Final residual = 0.00844998, No Iterations 5 time step continuity errors : sum local = 1.88172e+57, global = 3.94684e+45, cumulative = 3.94684e+45 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.0502332, No Iterations 17 DILUPBiCG: Solving for k, Initial residual = 2.0615e-20, Final residual = 2.0615e-20, No Iterations 0 ExecutionTime = 587.78 s ClockTime = 588 s Time = 0.206338 DILUPBiCG: Solving for Ux, Initial residual = 0.436017, Final residual = 0.0316758, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.403818, Final residual = 0.0338512, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.491748, Final residual = 0.0305268, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 208.867, No Iterations 1001 time step continuity errors : sum local = 4.23244e+62, global = 1.42026e+59, cumulative = 1.42026e+59 #0 Foam::error::printStack(Foam::Ostream&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 main in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception The second error after applying your changes in the fvsolutions are: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6.x-47a041d77269 Exec : simpleFoam Date : Mar 18 2010 Time : 13:08:16 Host : jish-laptop PID : 3244 Case : /home/jish/Desktop/impingingjet nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: p { solver GAMG; tolerance 1e-07; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; minIter 0; maxIter 2000; } // using new solver syntax: U { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-06; relTol 0.1; minIter 1; maxIter 2000; } // using new solver syntax: epsilon { solver smoothSolver; smoother GaussSeidel; nSweeps 1; tolerance 1e-06; relTol 0.1; minIter 1; maxIter 2000; } Reading field p Reading field U Reading/calculating face flux field phi --> FOAM FATAL IO ERROR: keyword SIMPLE is undefined in dictionary "/home/jish/Desktop/impingingjet/system/fvSolution" file: /home/jish/Desktop/impingingjet/system/fvSolution from line 20 to line 93. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 457. FOAM exiting Can you give me any suggestions. /jish |
Hi
Yup your parenthesis are not defined properly. Check for matching parenthesis. Something is cutting the dict reader before it hits the SIMPLE keyword. |
1 Attachment(s)
I am attaching my fvsolution, can you check it and tell me whats wrong, because I am trying, but keep getting the errors.
/jish |
Hi you are missing the semicolon a few places, this is C++ so you have to be sure that you have ; at the right places
/*--------------------------------*- C++ -*----------------------------------*\ |
1 Attachment(s)
hi
I am still getting error. Time = 0.166166 smoothSolver: Solving for Ux, Initial residual = 0.0275854, Final residual = 0.00146647, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0718824, Final residual = 0.000758482, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.968862, Final residual = 0.0409947, No Iterations 2 GAMG: Solving for p, Initial residual = 0.938635, Final residual = 0.00441988, No Iterations 1 time step continuity errors : sum local = 8.94404e+39, global = 1.23604e+35, cumulative = 1.15359e+35 smoothSolver: Solving for epsilon, Initial residual = 0.169669, Final residual = 1.73112e-23, No Iterations 1 bounding epsilon, min: -1.07468e+84 max: 1.76614e+89 average: 4.16457e+85 smoothSolver: Solving for k, Initial residual = 1.18578e-06, Final residual = 1.52363e-07, No Iterations 1 bounding k, min: -1.08842e+59 max: 8.52353e+80 average: 4.05931e+77 ExecutionTime = 1135.36 s ClockTime = 1136 s Time = 0.167079 smoothSolver: Solving for Ux, Initial residual = 0.570872, Final residual = 0.0457938, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.958293, Final residual = 0.0716294, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.999977, Final residual = 0.0660372, No Iterations 3 #0 Foam::error::printStack(Foam::Ostream&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #8 main in "/home/jish/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #9 __libc_start_main in "/lib/libc.so.6" #10 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception I have implemented your changes but after few iterations its still showing me the above error. I am attching my case again, let me know if there is anything wrong with the whole case. /jish |
Hi
You can see that k/epsilon is exploding as well as the time step continuity errors. The case setup should be ok, but here is something wrong with your initial boundary conditions or the scale of the mesh. Otherwise k/epsilon should not blow up like this. on a sidenote, if you are using simpleFoam deltaT should be 1. simpleFoam is a steady-state solver so no need to have a small deltaT. |
1 Attachment(s)
Do you think that the wall functions is creating this error. As I have tried to use the boundary condition similar to the pitzDaily tutorial. Does the kqRwallfunction and nutwallfunction, epsilonWallfunction causing the error? I have attached the boundary condition files let me know what would be potentially wrong. /jish |
Is it possible to describe more about role of deltaT. is it mean its magnitude has no effect on results accuracy? |
