-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   ZeroGradient pressure Outlet BC prob (adjustPhi.C) (http://www.cfd-online.com/Forums/openfoam/74037-zerogradient-pressure-outlet-bc-prob-adjustphi-c.html)
Stylianos March 23, 2010 06:52
Hello Everyone
I've been trying to set-up a Rotor-Stator case for MRFSimpleFoam (my goal is to obtain an initial solution to then use with turbDyMFoam for an unsteady calculation).
I've succeeded on getting a converged solution via MRFSimpleFoam but i observed that i had a strange pressure distribution near the outlet (a pressure step exactly at the last nodes before the outlet). After some search in previous threads i found out that a good idea is to use zeroGradient (with pRefCell and pRefValue) as outlet BC.
My initial BCs were:
U:
INLET
type flowRateInletVelocity;
flowRate 0.750;
value uniform (0 0 0);
OUTLET
type inletOutlet;
inletValue uniform (0 0 0);
P:
INLET
type zeroGradient;
OUTLET
type fixedMeanValue;
meanValue 0;
My modified BCs are:
U
INLET
flowRate 0.750;
OUTLET
type zeroGradient;
P:
INLET
type zeroGradient;
OUTLET
type zeroGradient;
but with the new BC set up (and although i initialized my U field with a sensible value) i get this error:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Specified mass inflow : 0.75
Specified mass outflow : 0
Difference : 0.75
Adjustable mass outflow : 0
I've then went to adjustPhi.C to check out (maybe i was missing something) and i've seen that the part that calculates Specified mass outflow, Specified mass inflow and Adjustable mass outflow has undergone a recent bug fix (// HJ, 12/Feb/2010) and i was wondering if someone had successfully used it since then ?
Thanks for your help
Stylianos
Stylianos March 23, 2010 09:44
Pressure step exactly at the last nodes before the outlet
https://mail.google.com/mail/?ui=2&i...f_g736snwy0&zw
kev4573 March 23, 2010 10:38
Your BCs on pressure are not well defined; try using total pressure on the outlet.
Stylianos March 23, 2010 13:28
If the outlet is part of the rotating portion of the mesh dose that create a problem for MRFSimpleFoam?
