[swak4Foam] funkySetField
Old   March 16, 2010, 10:15
Default funkySetField
Emanuele Leoni
lions85 is on a distinguished road
Hi, i'm trying to put here the mail i wrote to the creator of the funkySetField application in openfoam wiki. I didn't get any answer yet so i try also in this forum, maybe someone is able to help me.
Thank you Emanuele
Hi, i'm a master student of Politecnico di Milano, and I'm developing my master thesis work on openfoam. I found your utility and i think it is what I need. My problem is about a non premixed flame in which I have a very simple axial symmetric mesh with some boundaries. The point is that i need to set some non uniform initial conditions on this boundaries, principally related to U, epsilon and k. I tried using your utility and I managed to set the U field, but i tried to set the inletfuel patch using this command:
funkySetFields -field U -valuePatches "inletfuel" -expression 'vector((2.+0.167)*(1.+0.167)/2.*pow((pow(1.01,2.167)-pow(0.01,2.167)-(2.+0.167)*pow(0.01,1.167)),-1.)*117.2*pow((1.01*pos().x/0.0018),0.167),0,0)' -time 0
the result was:
Create time
Create mesh for time = 0
Time = 0
Using command-line options
Putting "vector((2.+0.167)*(1.+0.167)/2.*pow((pow(1.01,2.167)-pow(0.01,2.167)-(2.+0.167)*pow(0.01,1.167)),-1.)*117.2*pow((1.01*pos().x/0.0018),0.167),0,0)" into field U at t = "0" if condition "true" is true
Setting the patches
1
inletfuel
to fixed value
Setting 15830 of 15830 cells
Writing to "U"
End
In this way all the cells are filled with this condition, but i need the condition only in the inlet. So i think I didn't understand very well the -valuePatches option.
I have a question more: I want the condition for every time step: how i can set this?
I really hope you can help me.
Thank you very much
Emanuele
lions85 is offline   Reply With Quote
Old   March 16, 2010, 12:07
Michael Jaworski
mike_jaworski is on a distinguished road
I don't know about the -valuePatches option, but if this is a boundary condition, why not use groovyBC instead?
mike_jaworski is offline   Reply With Quote
Old   March 17, 2010, 07:57
Assistant Moderator
Bernhard Gschaider
Rerun FSF with the -keepPatches-option and "clear" the field. See http://openfoamwiki.net/index.php/Co...t-Room_Example
A fixedValue is not changed during the simulation. So if you set the patch at 0 it will keep that value. If your BC is transient then have a look at groovyBC as suggested in the other posting
Bernhard
[swak4Foam] funkySetField newbie29 OpenFOAM Community Contributions 2 September 12, 2012 01:50
Bubble in zero gravity conditions sega OpenFOAM Running, Solving & CFD 59 November 25, 2011 07:21
[Technical] Cell numbering sega OpenFOAM Meshing & Mesh Conversion 1 April 20, 2010 11:32
