Error: bouyantSimpleFoam command not found
Old   April 5, 2020, 14:09
Question Error: bouyantSimpleFoam command not found
Eduardo Miranda
Emiranda is on a distinguished road
Hi everyone!
I'm new using OpenFOAM and ubuntu's terminals as well.
I've done simulations with IcoFoam and simpleFoam solvers, using the blockMesh dictionary and then tapping the solver command as you know. Actually, I'm trying to use the bouyantSimpleFoam solver and when I want to perform the simulation, the terminal sends me the following message:
"Command 'bouyantSimpleFoam' not found, did you mean:
command 'bouyantSimpleFoam' from deb openfoam
Try: sudo apt install <deb name>"
And that's my problem, I don't know what to do actually. Thanks in advance if somebody knows how to fix it.
Regards!
Emiranda is offline   Reply With Quote
Old   April 6, 2020, 05:03
Yann
Yann will become famous soon enough
Hi Eduardo,
There is a typo in your command. The proper solver name is "buoyantSimpleFoam".
When you bump into the "command not found" error there are mostly two possibilities :
  • OpenFOAM environment is not sourced in your current session : you will not be able to use any of the OpenFOAM related commands.
  • OpenFOAM is properly sourced and you can use commands such as blockMesh or icoFoam. Then it means the command you are trying to use really does not exist. It might be misspelled, does not exist in the OpenFoam version you are using or maybe it has not been properly compiled.
When in doubt, you can always check the source code, especially the applications directory where you should find every solver and utilities available in your version.
Cheers,
Yann
Yann is offline   Reply With Quote
command, error, openfoam, solver, ubuntu
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
