[groovyBC] Error at the beginning of a simulation |
March 27, 2010, 11:50 |
Piotr Prusinski
New question concerning proper installation of a groovyBC. I have some strange situation here and maybe some of you know what it is. So, when I'm trying to run the simulation, using groovyBC, then I get something like below: Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/compressibleInterFoam" #5 main in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/compressibleInterFoam" #6 __libc_start_main in "/lib/libc.so.6" #7 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception Code:
libs ( "libOpenFOAM.so" "libgroovyBC.so" ) ; I feel that probably I made something wrong during the "installation" of groovyBC on my machine. Is it all right, that the path to the groovy library is: Code:
./OpenFOAM/piotr-1.6.x/lib/linux64GccDPOpt/libgroovyBC.so Code:
./OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/ |
March 27, 2010, 17:30 |
#2 | |
I think it is OK. Generally, we should put library in our own directory. Did you run the demo case in groovyBC package? Elliot |
March 27, 2010, 17:35 |
Piotr Prusinski
Good point, I have to check it... --------- OK I checked that. I ran the average-t-junction case and it crashed after the step t=0.429104 and just before calculating deltaT of the next step: Code:
Courant Number mean: 2.06335e+30 max: 6.04513e+31 #0 Foam::error::printStack(Foam::Ostream&) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::Time::adjustDeltaT() in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 main in "/home/piotr/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/pimpleFoam" #5 __libc_start_main in "/lib/libc.so.6" #6 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception -------- This time I ran wobbler. The simulation went smoothly without any errors and the results looks quite nice in ParaView. Strange Last edited by piprus; March 27, 2010 at 18:15. |
March 29, 2010, 14:24 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
March 30, 2010, 13:42 |
#5 | |
Piotr Prusinski
file path, groovybc, install, library |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 01:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
