problem with chtMultiRegionFoam tutorial...
Old   June 9, 2010, 09:42
Arrow problem with chtMultiRegionFoam tutorial...
Cyp
Cyprien
Cyp is on a distinguished road
Hi everybody !
I was trying to run the chtMultiRegionFoam/multiRegionHeater by the ./Allrun command. Some log files are creating, but it look as if nothing happens : the only directory remains the "0" folder.
I try another way (according to an online presentation) executing the following commands:
blockMesh -> OK
setSet -batch makeCellSets.setSet -> here I get the following error message
setSet: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
Do you have any ideas ?
Thank you for your help,
Cyp
Cyp is offline   Reply With Quote
Old   June 9, 2010, 10:35
m.nichols19 is on a distinguished road
Try this in Terminal:
sudo ln -s /lib/libreadline.so.6.1 /lib/libreadline.so.5
Tell me how that works out
m.nichols19 is offline   Reply With Quote
Old   June 9, 2010, 10:37
Cyp
Cyprien
thank you for your answer
in which directory do I apply your command line ??
Old   June 9, 2010, 10:45
The home directory. Sorry, I should have mentioned that.
Old   June 9, 2010, 10:58
Cyp
Cyprien
I still have the same problem...
Old   June 10, 2010, 09:39
Robertas N.
r08n is on a distinguished road
Try this:
ldd `which setSet`
and see if it can find libreadline.so.5. Is this file really present somewhere in /lib
or /usr/lib?
BTW, I ran this on my PC and it seems that setSet does not even depend on libreadline...
It would be helpful if you could inform that distro/version and OF version you are using
(that's the first thing to do when asking questions like this).
r08n is offline   Reply With Quote
Old   June 10, 2010, 12:04
Cyp
Cyprien
Hi !
when I type your command, I get :
libreadline.so.5 => not found
Moreover, when I want to edit the Allrun file, I get the following warning :
kde4-config: /USER/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/libkdecore.so.5)
kde4-config: USER/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib64/libkdecore.so.5)
Is there any link ??
I have a OpenSuSe 11.2 and I run OpenFOAM 1.6
Old   June 10, 2010, 12:13
Cyp
Cyprien
I saw a similar topic :
http://www.cfd-online.com/Forums/ope...-tutorial.html
but there is no tips that can help me
Old   June 10, 2010, 12:46
Robertas N.
Hi !
Do you have libreadline installed? I cannot give you many details, because I'm not using OpenSuse, but you might try smth like "yum install libreadline5" or so. Search for info
about this lib under O-suse.
Evidently, your editor tries to use the system libraries (like libkdecore), but libstdc++
is "substituted" by the OF library, because of the OF/etc/bashrc script. Try to open the console, do not source the OF/etc/bashrc, and then run an editor. See if it works.
Make sure sourcing OF/etc/bashr is not included in your (or system-wide) .bashrc script.
Also you may try some text-mode editor, like 'vim' or similar.
These are just some quick guesses, I'm not sure if this helps, but maybe you'll notice smth informative.
Old   June 11, 2010, 11:36
Cyp
Cyprien
thank you r08n your very good advices. I have installed the libreadline5 librairie, and now my calculation successfully ran.
I encounter a new problem now : I can't view any fields with paraFoam. Do you have any idea ?
Old   June 14, 2010, 10:35
Robertas N.
I had a similar problem with viewing fields in multiple regions. The short procedure that worked for me is this:
1) after setting up the geometry with multiple regions (with setSet, setsToZones, splitMeshRegions), a new folder is created 0.001. It contains a separate folder for each region, and each such subfolder contains a folder "polyMesh"; e.g., case_name/0.001/region1/polyMesh/, etc.
2) while running the simulation, appropriate folders for times are created, as usual.
3) Now, after the simulation ends, link or copy the folder "polyMesh" from time 0.001 subfolder of appropriate region into the subfolders of respective regions in other time folders; e.g. 0.001/region1/polyMesh --> 10.001/region1/polyMesh, 0.001/region2/polyMesh --> 10.001/region2/polyMesh, etc. Repeat for all the regions and times like this:
for t in 10.001 20.001 30.001 ...
do
for r in region1 region2 ...
do
ln -s 0.001/$r/polyMesh $t/$r/polyMesh
done
done
4) from within the case folder, run foamToVTK for each region:
foamToVTK -useTimeName -region region1
etc. (repeat for each region). This should create a folder with the structure like this:
case_name/VTK/region1/grid_10.001.vtk etc., i.e., .vtk files for each region and time.
5) run 'paraview' (not paraFoam) and open these *.vtk files.
There are instructions here:
http://openfoamwiki.net/index.php/Ho...rocMultiregion
but it seems that I used a slightly different procedure, as described above. I'm not sure if
I was doing the things right. Any comments?
Old   June 14, 2010, 10:39
Cyp
Cyprien
thank you very much for your answer !
Indeed, it perfectly works when I use paraview instead of paraFoam
Old   June 14, 2010, 10:58
Hello ro8n,
The following is my procedure for viewing fields in multiple regions in the multiRegionHeater tutorial:
5. Create the remaining constant folders by entering the following commands in Terminal:
mkdir constant/heater
mkdir constant/leftSolid
mkdir constant/rightSolid
6. Softlink the mesh from the first time step of each region to the constant directory of each region by entering the following commands in Terminal:
cd constant/bottomAir
ln -s ../../0.001/bottomAir/polyMesh polyMesh
cd ../../
cd constant/topAir
ln -s ../../0.001/topAir/polyMesh polyMesh
cd ../../
cd constant/heater
ln -s ../../0.001/heater/polyMesh polyMesh
cd ../../
cd constant/leftSolid
ln -s ../../0.001/leftSolid/polyMesh polyMesh
cd ../../
cd constant/rightSolid
ln -s ../../0.001/rightSolid/polyMesh polyMesh
cd ../../
7. Convert the format of each region to VTK by entering the following commands in Terminal:
foamToVTK -region bottomAir
foamToVTK -region topAir
foamToVTK -region heater
foamToVTK -region leftSolid
foamToVTK -region rightSolid
8. Run ParaView by entering the following command in Terminal:
paraFoam
9. Open the following folders in ParaView:
VTK/bottomAir/multiRegionHeater_..vtk
VTK/topAir/multiRegionHeater_..vtk
VTK/heater/multiRegionHeater_..vtk
VTK/leftSolid/multiRegionHeater_..vtk
VTK/rightSolid/multiRegionHeater_..vtk
best regards,
Matt
Old   June 15, 2010, 06:17
MSarkar
msarkar is on a distinguished road
do
do
done
done
Hi Robertas,
I faced same problem to visualize the results from multi-region simulation and followed your instructions to convert the results to VTK format but it did not work for me. It created all region folders within VTK folder and region folder it creates caseName_time.vtk file (caseName/VTK/region/caseName_time.vtk) but I am not able to visualize the field values (like p, T, U etc). Only I can see the mesh. When I uploaded this vtk file in paraview it gives me option to display Solid Color, CellID and cellNormals, no field name like p, U, T etc. I followed your suggestion exactly but I don't know what is wrong there. Please help me to visualize the results. I ran chtMultiRegionFoam solver and I am using OF-1.6.x version (freefoam).
Thanks
M. Sarkar
msarkar is offline   Reply With Quote
Old   June 18, 2010, 06:05
Robertas N.
I'm not sure about this problem, just guessing: open any .vtk file with a text editor
and see if there any field data; for example, for the field 'rho' there must be a string like
'rho 1 130 float' and then some numbers in binary (looks like random symbols) or ascii format.
Before running foamToVTK, is there field data (the files for U, T, rho, phi, etc. as appropriate) in the appropriate time and region subfolders (e.g., 20.001/region1/U , etc)?
Are the polyMesh folders in region folders linked to respective region folders in 0.001?
(e.g., 10.001/reg1/polyMesh --> 0.001/reg1/polyMesh; i.e., if there are no mixups between different regions).
These are some quick guesses that came to mind.
Don't follow me yet -- I'm still a n00b in these matters... Much of what I have written so far is a guesswork which is still in progress...
Old   June 28, 2010, 03:48
MSarkar
Hello Robertas,
I think it was my bad, I did not open right vtk file. Now I am able to visualize the results. Thanks a lot for you post.
Regards
M. Sarkar
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 15:22
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 02:32
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
