Thanks Bruno. FoamToVTK is a little impractical with the setup I have going. After a little more digging, I found that it depends on the data fields I have loaded, some of which aren't calculated for all time steps. Therefore it seems like a plug-in bug.
Has anyone else used the vanilla ParaView 3.8.1 with OF 1.6, and if so what adjustments or tweaks have you had to make for it to work seamlessly? I like the stability of 3.8.1 in general and would like to use it as the default. |
Hi Marco and Bruno,
@Marco: I see the problem with PV 3.8.1 (and only with 3.8.1, but not with 3.8.0 nor 3.9.0) too with a minor difference being I always see the problem regardless of what field I load. If we are discussing the same problem nonetheless, Merge Blocks should work. @Bruno: Quote:
#28 0x00007ffff7b59e9d in pqSelectionInspectorPanel::updateSelectionGUI() () Code:
commit 9cd0f355d03600e97b9b082dee0fa73ec62c4cac Takuya |
Hi Takuya,
My apologies to you Takuya, for not fully thinking it through. Best regards, Bruno |
