March 8, 2010, 15:25 |
Ggi help please
Jason Eason
Rep Power: 16 |
I want to simulate a co-axial rotor system, I've modified the MRFSimpleFoam case, with the implementation of the ggi, but I don't understand the what will represent the insideSlider. I created a cylinder around each rotor to represent the outSlider. Also, with MRFSimpleFoam will I have to use the dynamicMechDict to control the angular velocity, because of the use of ggi, or would I have to use the MRFZones file for the purpose.
Thank you in advance. Jason
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 |
March 8, 2010, 22:00 |
Masashi Ohbuchi
Rep Power: 16 |
If you mention about mixerGgi tutorial case, insideSlider is a ggi patch at outside of the Rotor. And you should not define dynamicMeshDict for MRFSimpleFoam. You need MRFZones only. If you use turbDyMFoam, you need to define dynamicMeshDict.
March 8, 2010, 22:42 |
Jason Eason
Rep Power: 16 |
Ohbuchi, Thank you for your reply, should I not include the outsideSlider, or should I define the insideSlider and outsideSlider as the same entity?
March 9, 2010, 02:29 |
Masashi Ohbuchi
Rep Power: 16 |
You should define outsideSlider too.
For use of GGI, you should define a pair of GGI patches, one is rotor-side, other is stator-side. |
March 13, 2010, 15:07 |
Jason Eason
Rep Power: 16 |
Sorry, I have another question I've created 4 blocks, using 16 points to create, a ring around my mesh, which is the in/outsideSlider, but somehow the results are unusual. I've arc the blocks also, arc a b (x y z), the ring won't closed, somehow the x or z value is the circumference, instead on the points in which the line arcs through. Any thoughts on what is wrong or what I'm doing wrong?
[IMG]file:///E:/arc.png[/IMG]Edit: I've done may round meshes before so I know my syntax is correct, when I erase the arc functions my image forms a square/diamond as expected.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 Last edited by JulytoNovember; March 13, 2010 at 19:49. Reason: Adding pics and info |
March 13, 2010, 19:09 |
Masashi Ohbuchi
Rep Power: 16 |
It seems like a problem on usage of blockMesh utility.
Please refer ti OpenFOAM UsersGuide Chapter 5.3. |
March 13, 2010, 22:12 |
Jason Eason
Rep Power: 16 |
I found my problem and it was in the blockMeshDict file, Thank You Ohbuchi, you were corrct sorry for flooding the forum.
Edit: Have completed my case file, MRFSimpleFoam with ggi implementation, I found all step setting cells and faces, I've included eveything in the pertinent files and folders, and deleted the dynamicMeshDict. Following instructions from http://openfoamwiki.net, setBatch and decomposePar, when I run decomposePar or the simulation itself I get this error Attempt to cast type patch to type lduInterface From function refCast<To>(From&) in file /OPENFOAM/.../src/OpenFOAM/lnInclude/typeInfo.H at line 106 Any help would me appreciated. Thank You. Jason I solved this problem by addressing the boundary file in the constant directory, and changed the type from patch to ggi, and had to add the shadowPatch and bridgeOverLap and zone.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 Last edited by JulytoNovember; March 15, 2010 at 15:18. Reason: Solved |
March 20, 2010, 00:01 |
Jason Eason
Rep Power: 16 |
When I try to run my simulation I get a segmentation fault. So I removed the functions at the end of the ControlDict, the website info was located in the optional category, the simulation then ran, but the mesh didn't rotate at all. Also my boundary file clears the zone and shadowPatch and the bridgeOverlap always changes to off. Any thoughts? Anyone?
March 20, 2010, 02:53 |
#9 |
Masashi Ohbuchi
Rep Power: 16 |
If you still use MRFSimpleFoam, mesh never rotate. MRFSimpleFoam is a steady state solver using multireference frame ( Frozen Rotor ). This Frozen Rotor method simulate flow field using computational mesh relative position between rotor and stator region is fixed, and taking into account centrifugal force and Coriolis force in impeller region only.
If you want to rotate actually, you should use turbDyMFoam. |
March 20, 2010, 12:01 |
#10 |
Jason Eason
Rep Power: 16 |
I thought that the ggi could rotate any mesh, I know that MRFSimpleFoam doesn't rotate, but shouldn't adding the ggi make it rotate, I need a multizone case thats why I chose MRFSimpleFoam. Is it possible to have multi-moving meshes with anything other than MRFSImpleFoam?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 Last edited by JulytoNovember; March 20, 2010 at 12:10. Reason: Correction |
March 21, 2010, 20:02 |
#11 |
Masashi Ohbuchi
Rep Power: 16 |
GGI stands for general grid interface, so this doesn't directly concerned with sliding mesh.
This is quite useful for define interface between patches with discontinuous face mesh. |
March 26, 2010, 23:31 |
#12 |
Jason Eason
Rep Power: 16 |
You suggested turbDyMFoam but I don't see a case in the directory, I'm not skilled enough to create the files in the system folder, is there another case in which the system folder can transfer without any modifications? Can turbDyMFoam run a co-axial rotor system, which intels one rotor above the other turning in opposite directions?
March 28, 2010, 07:19 |
#13 |
Masashi Ohbuchi
Rep Power: 16 |
I suppose mixerGgiFvMesh support only one rotating zone. If you want to handle two rotating zone, you should modify it.
April 8, 2010, 16:21 |
#14 |
Jason Eason
Rep Power: 16 |
My mesh checks is ok my cellzones are set to movingCells, the boundary file ggi is set, my simulation ends with a floating point exception. The interations max out no matter of high I raise them(5000). DecomposePar shows no errors. Any ideas why this may be happening?
ggi mrfsimplefoam |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Difference between ggi and overlapGgi? GGI Tips and Tricks? | philippose | OpenFOAM Running, Solving & CFD | 7 | January 16, 2013 09:40 |
GGI (General Grid Interface) Connections | feixiangniao | CFX | 4 | January 14, 2010 19:51 |
CFX GGI Interface Error (non-overlapping) | surge519 | CFX | 1 | August 3, 2009 18:54 |
GGI ERCOFTAC and general questions | david | OpenFOAM Running, Solving & CFD | 8 | August 25, 2008 09:22 |
