Home > Forums > OpenFOAM
Mixed BC - heat transfer - laplacianFoam
Like Tree30Likes
Old   September 20, 2012, 18:22
Default convective bc based on mixed
  #41
hawkeye321 is an unknown quantity at this point
Thanks for the comment.
Is the implementation of convective bc by mixed type in the following way?
refValue = Tinf
refGradient = 0
valueFraction = 1/(1+k/(h*mag(delta())))
value = ???
hawkeye321 is offline   Reply With Quote
Old   September 20, 2012, 18:25
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
You can find the description here, just read more careful
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Advanced Process Simulation of
Solidification and Melting"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
Franz-Josef-Str. 18
A - 8700 Leoben
Österreich / Austria
Tel.: +43 3842 - 402 - 3125
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   September 21, 2012, 18:03
Default Problem when formulating the energy equation with enthalpy
  #43
Hi Foamers
Following the discussions above, I implemented the groovyBC for simple 2D heat conduction problem. The problem is the cooling of plate by imposing a convective bc from one side. My results seem to be reasonable when I formulate the energy equation with temperature, I mean
Density*Cp*(dT/dt) = k(d2T/dx2)
But when I am formulating it vs enthalpy as
Density* (dh/dt) = k(d2T/dx2),
the temperature reach values less than Tinf, which is wrong. Any ideas?
Old   September 21, 2012, 18:31
Do you make correction loops for each time step?
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Old   September 21, 2012, 19:06
makaveli_lcf thanks fro reply
Well this is the main part of the code
fvScalarMatrix TEqn
Density*fvm::ddt(h)
- Cond*(fvc::laplacian(T))
TEqn.solve();
forAll( T, celli)
T[celli] = (h[celli]-(gL.value()*Latent.value()))/(Cp.value());
is this what you ask for?
Old   September 21, 2012, 19:13
Ok then you should put a coupling loop (like pimple e.g.) around it, because temperature values which you use in the energy equation for the enthalpy are from the previous iteration and do not meat the energy equation after you calculate them from enthalpy.
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Old   September 21, 2012, 19:18
Do you mean previous time step? My formulation is explicit and I am not concerned about using the previous time step values for T in energy equation. By the way, with the same formulation, I get reasonable results when I use constant temperatures as the boundary condition. So I am almost sure that the problem is in the way I have applied the boundary conditions.
Old   September 21, 2012, 19:44
No I mean previus ITERATION:
Step #1: you take T from old time step (at least OpenFOAM does it for you in any case) and use them to solve dh(@_new_time_step)/dt=k*laplacian(T(@_old_time_step))
Step #2: update T from new calculated h values
Step #3: since T does not fullfil dh/dt = k*laplacian(T) calculate h using T from Step #2
a) If you pretend, that your solver is transient, you have to make coupling loops Step #1-#2 so many times, that T will correspond to the energy equation. Low temperature values can be explained (if you speak about some transient point in your calculation) by the fact that your system h-T is not converged for the current time step.
b) If you use transient way to get a steady state solution it is not necessary. But do not try to explain intermediate T values then
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Old   September 21, 2012, 19:48
Thanks for your comments, but I still think that there is a problem in implementing boundary conditions and not in the solver, because the solver gives good results with fixed value bc for temperature.
Old   September 21, 2012, 19:56
You are trying to compare Dirichlet and Robin boundary conditions. First one is fixing your solution to some values, the second contains gradients and nonlinearity, so can couse oscilations around final solution and needs some iterative process if you treat it explicit way and not implicitly... But Ok, it is your choise how check it...
Best regards,
Franz-Josef-Str. 18
A - 8700 Leoben
Old   October 9, 2012, 09:35
Default limit of applicability of the 1st order approx.
  #51
Elisabet Mas de les Valls
elisabet is on a distinguished road
Dear all,
I'm now interested in such a boundary condition (applied to other phenomena). I first must thank you all for your work! I'm sure it will be very useful
I just want to mention that the 1D approach is valid for small enough values of Biot number. And NOTE THAT BIOT=1/C!!!!!
For planar surfaces, typically Bi<0.1 is enough. This means that wall tangential temperature gradients does not alter the heat flux (what in fact just states that the boundary and internal nodes are close enough to consider 1D conduction)
For 1D conduction in planar geometries, with no thermal production and constant thermal conductivity, the temperature difference that appears in Fourier's Law is, definitely, first order.
elisabet is offline   Reply With Quote
Old   January 27, 2013, 21:26
Default changing htot value did not affect the results
  #52
sorush ahmadian
sahmadian is on a distinguished road
Dear All,
Thanks for the good information provided here. I am solving the heat equation (enthalpy) for a food sphere with phase change. I implemented the groovyBC for my problem and in the first glance it seemed to work fine. But when I tried to change the convective heat transfer coefficient (htot) no change in the results occurred and I got the same results. I have tried all the suggestions in this post except the wallHeatTransfer which did not work for me. Any ideas?
best
SA
sahmadian is offline   Reply With Quote
Old   July 4, 2013, 12:17
Default Difference between parameter in groovyBC
  #53
franzi_ is on a distinguished road
Dear all, Thanks for the useful discussion, but I still did not understand the groovyBC completely.
1. What is the difference between the parameters? valueExpression to set Dirichlet-condition, gradientExpression to set Neumann and what is then fractionExpression? The explanation from http://openfoamwiki.net/index.php/Contrib_groovyBC doesn't help me...
2. Still I did not understand the derivation of:
type groovyBC; variables "htot=1000.0;Tinf=20.0;rho=800.0;cp=385.0;k=DT*rho *cp;"; valueExpression "Tinf"; fractionExpression "1.0/(1.0 + k/(mag(delta())*htot))";
, but it works in my case. So I want to know why
GroovyBC is such a powerful tool, so I finally want to understand the tool in detail. Any hints?
Thanks a lot in advance
franzi_ is offline   Reply With Quote
Old   October 6, 2013, 17:14
eric
armyou is on a distinguished road
This is a life saver!!!
armyou is offline   Reply With Quote
Old   March 28, 2014, 14:17
Alfonso C
acubillosv is on a distinguished road
Thank you for the explanation. But, how can I use the 1/deltaCoeff() in the BC file T ??
Many thanks.
Alfonso C
acubillosv is offline   Reply With Quote
Old   May 4, 2014, 20:02
Jonas
jnichel is on a distinguished road
I'm new in openfoam. I'm willing to implement this bc:
k (Tf - Tc)/x + h (Tf - Tinf) = 0
k, Tc, x, Tinf are given values.
I want to find Tf, but h is not constant, h should be calculated in each step based in the temperature gradient (-k dT/dy) / (Tf-Tinf).
Is it possible to be done? How could I implement it?
ps. I would give initial values for Tf and h.
jnichel is offline   Reply With Quote
Old   August 25, 2015, 02:18
Default Fixed Heat Flux In OpenFOAM
  #57
AliMahmoodi is on a distinguished road
I have introduced Temperature equation in icofoam , finally it compiled successfully. Now i am going to solve laminar pipe flow, so i need to implement a constant heat flux on wall. i have heard fixedgradient boundary condition does not implement a constant heat flux.
has any one know how i can improve this problem?
do i need groovy Bc?
i dont know how to work whit groovy Bc?
AliMahmoodi is offline   Reply With Quote
Old   August 25, 2015, 21:14
Default Changing heat transfer coefficient
  #58
P_P
P_P is on a distinguished road
due to your posts I was able to approximate the heat loss in a rectangular bubble column which consists of acrylic glass and is insulated with styropor. At t=0 the bubble column contains water with a temperature of 46°C. As time progresses, the bubble column is fed with air which has a temperature of 18°C. The direct consequence is that the water temperature drops. In order to simulate this heat loss I used groovybc:
type groovyBC;
value uniform 319.15;
variables "k_1=0.597;htot=1/(0.03/0.035+0.01/0.19+1/0.021);Tinf=291.15;";
fractionExpression "1.0/(1.0+k_1/mag(delta())*1/htot)";
The number 0.021 represents the external heat transfer coefficient due to natural convection. In order to describe the heat loss more precisely, I would like to update the external heat transfer coefficient after each timestep. Therefore I need to determine the outer wall temperature. Has someone got an idea how this problem can be handled?
Greetings
P_P
P_P is offline   Reply With Quote
Thread Tools
Trackbacks are On
Heat transfer coefficient - what is waht Stan FLUENT 20 March 11, 2014 11:42
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
CFX Heat Transfer RJamison CFX 0 July 24, 2008 12:11
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
