Set liquid level in a Tank
Hello! I want to simulate a two phase mixing tank (air-water). I want to set the water level at a high of 0.26 meters in the y direction in the tank before the operation starts.
My overall domain is: (-0.129986 0 -0.129999) (0.13 0.35 0.129999) I want to simulate two cases: 1. Without airation, using MRFSimpleFoam. 2. With airation, using MRFTwoPhaseEulerFoam. For the first case I don't know how to set the liquid level. For the second case I have tried setFields, but I don't know if it is correct. My setFieldsDict is: regions ( boxToCell { box (-0.129986 0 -0.12.9999) (0.13 0.26 0.12999); fieldValues ( volScalarFieldValue alpha 0 ); } ); Could anybody help me to set the liquid level in the first case and say to me if in the second case the configuration is ok? Thanks in advance. |
The alpha value should be set to 1 not 0.
Best regards, Niels |
Try something like this:
defaultFieldValues ( |
But alpha is the dispersed phase volume fraction right? so if i put alpha equal to 1 it is like if my tank is fill with air, not with water I think. I am confused. Correct me if I am wrong. Thank you for your reply.
MRFSimpleFoam is a single-phase solver, so you cannot specify the level of the liquid, since there is only one phase. I assume MRFTwoPhaseEulerFoam is your extension of twoPhaseEulerFoam, since I've not seen a solver with that name :-) However you are correct: alphas is the volume fraction of the dispersed phase. As suggested above, setFields should work to set alpha. Take a look at the examples for twoPhaseEulerFoam. Best, |
