directMappedPatch in OpenFoam 1.6
Old   April 1, 2010, 06:28
Default directMappedPatch in OpenFoam 1.6
Oli
olhe0002 is on a distinguished road
Hi!
I'm trying to use directMappedPatch in order to sample the fluid-velocity
at point x/y/z to a boundary (by using an offset).
I get the message:
FOAM Warning :
From function directMappedPatchBase::calcMapping() const
in file directMapped/directMappedPolyPatch/directMappedPatchBase.C at line 451
The actual cell/face centres picked up using offset (0 0.33 0) are not
on a single plane. This might give numerical problems.
At patchface (-70.1184 25.6462 2.17446) the sampled cell/face (-70.12 26.0355 2.17448)
is not on a plane 0.390814 offset from the patch.
You might want to shift your plane offset. Set the debug flag to get a dump of sampled cells.
Does somebody know this message?
Best Regards
olhe
olhe0002 is offline   Reply With Quote
Old   April 8, 2010, 10:54
Marco
om3ro is on a distinguished road
I got a similar error message with directmappedpatch, but i solved by using the updated version of openfoam 1.6.x .
there should be a bug in directmappedpatch of version 1.6 .
hope this helps.
marco
om3ro is offline   Reply With Quote
Old   April 8, 2010, 12:35
Thomas Baumann is on a distinguished road
I'm working with OpenFOAM 1.6. You get this warning message, but mapping works in OF 1.6. I solved different simulations and validated it (e.d. laminar pipe flow).
Regards Thomas
Thomas Baumann is offline   Reply With Quote
kOmegaSST in openfoam 1.6 Gearb0x OpenFOAM 2 March 3, 2010 06:02
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 12:46
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
