-   OpenFOAM (
-   -   How to install ParaView-3.6.1 in OpenFOAM-1.5-dev and OpenSuse 11.2 (
pcaron April 7, 2010 11:06
Dear Forum,
I've used OF for a while. So, I installed several versions in different machines and configurations.
This week I realized that the topo mesh changes works only in version 1.5-dev. (Thanks to Prof. H. Jasak in post
When I started the installation I had some issues...The most important is that the ThirdParty directory differs from version 1.6.x (yes, this is obvious, but I want to use paraview-3.6.1) So, these are the steps I followed to have a working paraview (I assume you downloaded the OF-1.5-dev and installed):
  1. Install cmake. In opensuse 11.2 the version is 2.6.4
  2. Download the ThirdParty directory for version 1.5 as usual
  3. Download the ThirdParty directory for version 1.6 as usual
  4. We will use the ThirdParty from 1.5 with some extras from 1.6. So copy de following directories and scripts to the 1.5 directory
    1. make*
    2. paraview-3.6.1
    3. tools
    4. qt-x11-opensource-src-4.3.5 (this one downloaded as indicated in OF 1.6 instructions).
  5. Modify cmake-2.4.6 to OLDcmake-2.4.6 (this way we will use system cmake)
  6. Modify the following settings
    1. In $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/apps/paraview3
      • export ParaView_VERSION="3.6.1"
      • export ParaView_INST_DIR=$WM_THIRD_PARTY_DIR/paraview-$ParaView_VERSION
    2. In $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/
      • compilerInstall=System
  7. Compile Qt with ./makeQt
  8. Compile Paraview with ./makeParaView -mpi -qmake $HOME/OpenFOAM/ThirdParty/qt-x11-opensource-src-4.3.5/bin/qmake
  9. Compile PV3FoamReader as usual
  10. In a no english system you need to add the following to the paraFoam script: export LC_ALL=C
As you can see they are several steps, that's the reason why I wanted to post them here. I hope I can help somebody.
