rhoPimpleFoam and sort of vortex tube
Old   July 15, 2011, 09:10
Default rhoPimpleFoam and sort of vortex tube
Pierre Castellani
pcaste12 is on a distinguished road
Hi all,
I am quite new in Foam and CFD sorry about my ignorance! I have read lots of post and try lots of different configuration but unfortunately I didn't make it work.
I would like to simulate the effect of the heat exchange into a vortex tube using inlet air to a certain speed. I am pretty sure that I didn't use the correct solver with the correct values. I put some result of simulation too.
here is part of the result:
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0.777335, global = -0.191246, cumulative = 404.083
rho max/min : 8.861e+12 -1.13053e+13
bounding p, min: -9.94366e+19 max: 7.80438e+19 average: -3.31783e+15
DICPCG: Solving for p, Initial residual = 0.989448, Final residual = 0.00447131, No Iterations 4
time step continuity errors : sum local = -9.44222e+10, global = 232.563, cumulative = 636.646
rho max/min : 1.16035e+17 -2.71668e+14
bounding p, min: -2.38947e+21 max: 1.03977e+24 average: 5.68377e+19
DICPCG: Solving for p, Initial residual = 0.986677, Final residual = 0.00929993, No Iterations 8
time step continuity errors : sum local = -133.181, global = 1, cumulative = 637.646
rho max/min : 2.23377e+15 -1.37108e+15
bounding p, min: -1.22796e+22 max: 1.97893e+22 average: 1.312e+19
DICPCG: Solving for p, Initial residual = 0.842719, Final residual = 0.00630697, No Iterations 11
time step continuity errors : sum local = 7.46699, global = 0.99952, cumulative = 638.645
rho max/min : 1.02758e+26 -6.25816e+25
bounding p, min: -5.57688e+32 max: 9.1386e+32 average: 1.95082e+28
DILUPBiCG: Solving for epsilon, Initial residual = 0.189303, Final residual = 4.05564e-06, No Iterations 37
bounding epsilon, min: -6.18411e+45 max: 1.28338e+50 average: 1.42126e+46
DILUPBiCG: Solving for k, Initial residual = 0.874965, Final residual = 9.08666e-07, No Iterations 3
DILUPBiCG: Solving for Ux, Initial residual = 1.38884e-12, Final residual = 1.38884e-12, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 2.89562e-12, Final residual = 2.89562e-12, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 5.69284e-13, Final residual = 5.69284e-13, No Iterations 0[0] #0 [1] #0 [3] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)Foam::error:rintStac k(Foam::Ostream&)DILUPBiCG: Solving for h, Initial residual = 0.0837411, Final residual = 0.00105101, No Iterations 1
in "/opt/openfoam171/lib/linux64Gcc in in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFDPOpt/libOpenFOAM.so"
OAM.so"
I attach all the case for those who will kindly look at it.
Any help wil be welcomed.
Pierre.
pcaste12 is offline   Reply With Quote
RhoPimpleFoam calculation of natural and forced convection Daniel_Jung OpenFOAM 0 September 22, 2010 05:02
