-   OpenFOAM (
-   -   Multiple domain/Multiple material problems... possible or not? (
Amiga500 April 14, 2010 04:58
Hi FOAMers,
As above - can OpenFOAM handle multiple domain/multiple material problems with interior boundaries allowing fluid to pass between each domain?
I know the fluentMeshToFoam converter cannot handle multiple materials, but I am not sure whether that is a converter limitation, or a limitation for OpenFOAM in general...
(The multiple material points are required for post processing - we are looking at fluid compositions over time in multi-cell chambers)
If OF can handle multiple material/domain problems; I'm happy to go off and hunt down the technique myself, but of course any guidance is very welcome! :)
benk April 14, 2010 15:32
You can do this using a number of techniques:
1) conjugateHeatFoam : see but this is only available in the -dev versions.
2) chtMultiRegionFoam
3) You can "map" transport properties between submeshes and a main mesh.
Out of those 3, I prefer conjugateHeatFoam.
