April 20, 2010, 05:14 |
simpleFoam solver
Jay
Hi all
I am new to OpenFOAM i want to use simpleFoam solver an my problem is... The problem is just like flow over a square cylinder but the inlet is having zero velocity but the square box is having some velocity say 2 m/s. Should I use moving wall concept? and What is kqRWallFunction in k file in 0 folder and epsilonWallFunction in epsilon file? i mean how do i find the values of both? Thanks in advance |
April 22, 2010, 09:42 |
Can you elaborate on the problem you are trying to solve? Im not sure I see the difference between a stationary object in a fluid flow of 2m/s and an object moving at 2 m/s through a (quasi-)stationary fluid.
The functions you are speaking of are to determine the initial behaviour of k and epsilon (turbulent kinetic energy and its dissipation rate) at the walls, as I understand. If the fluid velocity around the the object is 0 initally, there shouldnt be any turbulence. |
April 23, 2010, 01:15 |
Jay
Hi Graham
Actually I want to solve two cases 1. The object is moving and the fluid is stationary. 2. the object is steady and fluid is moving. so I want to ask in both the case how would I determine the initial behavior of k and epsilon (turbulent kinetic energy and its dissipation rate) at the walls.as velocity is 2m/s for object in first case and for fluid in second case. Thanks |
OpenFoam profiling the solver simpleFoam | andre | OpenFOAM Programming & Development | 9 | April 29, 2017 08:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
snappyMesh Motor Bike case for simpleFoam solver | s.sivakumar | OpenFOAM Pre-Processing | 0 | July 23, 2009 00:51 |
snappyMesh Motor Bike case for simpleFoam solver | s.sivakumar | OpenFOAM Running, Solving & CFD | 0 | July 22, 2009 08:00 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
