Add additional scalar to turbulence model
Old   April 20, 2010, 11:58
Default Add additional scalar to turbulence model
John Weaver
john_w is on a distinguished road
I am in the process of modifying one of the compressible turbulence models (k-omega SST) to utilize a variable Prandtl number. As Prt is a function of kinematic eddy viscosity and the thermal diffusivity (alphat_), it is first necessary to calculate local values of alphat_. To do this, it is necessary to have access to the scalar temperature.
In order to do this, I have added the following lines to my modified version of the k-Omega SST turbulence model header file
//- Return the temperature
virtual tmp<volScalarField> thermophysicalModel_.T() const
return T_;
However, this addition causes a compilation error -
error: ‘thermophysicalModel_’ declared as a ‘virtual’ field
How should this field be declared?
I have wondered if it is necessary to also add an additional expression to the turbulenceModel.H base class as well? If so, what might that expression be?
Any thoughts here would be much appreciated.
Thanks in advance,
John
john_w is offline   Reply With Quote
Old   December 23, 2010, 12:45
usergk is on a distinguished road
Hi
Does anyone know how to implement variable Prandtl number?
Thanks,
gk
usergk is offline   Reply With Quote
scalar, turbulence model
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
turbulence model question Jason Wei Main CFD Forum 1 May 6, 2003 00:45
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
